| Forum topic by robdem | posted 381 days ago | 930 views | 0 times favorited | 9 replies | ![]() |
381 days ago |
Made a mirror frame out of cherry would like to know if couple of coats of tung oil would be ok for a finish.Going to do two coats of a 50 /50 mix of tung oil and mineral spirits and then two coats of pure tung oil. any and all comments please |
9 replies so far
#1 posted 381 days ago |
Bathroom mirror, no, bathrooms are too humid. Any other room should be fine. -- |Statistics show that 100% of people bitten by a snake were close to it.| |
#2 posted 380 days ago |
I use oil on projects for the bathroom with no problems. Mirror, vanity, etc. The moisture in the bathroom during showers does not linger long enough to significantly affect the wood. With that said, my blend of oil uses 1/3 oil, 1/3 spirits, and 1/3 varnish, so the varnish may give me a slight amount of protection you won’t get with your mixture. If you are worried about it, wait for the oil to dry then coat it with shellac. -- Kelby |
#3 posted 380 days ago |
Kelby, Your mixture is close to the mixture I use for gunstocks. It’s the same as Tru-Oil gunstock finish. The varnish gives a lot more protection than just tung oil. I mix pure tung oil and mineral spirtis 50-50 by weight, then mix the resulting mixture 50-50 by weight with external spar varnish. The first couple of coats, I rub in tung oil and mineral spirits with extra fine stainless steel wool, after the pores are filled and the surface is smooth, I add varnish and keep rubbing in additional coats. The last few coats are rubbed in with just my fingers. The warmth from your hands makes a finish that can’t be duplicated with anything else. -- Hal, Tennessee http://www.first285.com |
#4 posted 379 days ago |
Depending on the bathroom and personal habits, pure tung might work but oil isn’t much of a barrier to moisture and it would be a shame for the mirror to warp. Mixing in some varnish should beef it up enough that it would be fine. -- |Statistics show that 100% of people bitten by a snake were close to it.| |
#5 posted 379 days ago |
Wormil Hal Kelby thanks for the information going to try both mixtures have two projects that will need finishing . thanks for the help. Will post pics when done. |
#6 posted 377 days ago |
You may want to first lay down a washcoat of 1lb cut shellac before applying the tung oil. Cherry can get blotchy due to uneven grain. You can test for this by seeing how the bare wood reacts to some alcohol. There is an article in the current issue of FWW covering sealing: http://www.finewoodworking.com/SkillsAndTechniques/SkillsAndTechniquesPDF.aspx?id=34782 -- - Nicholas, Silver Spring, MD http://AffineCreations.com |
#7 posted 377 days ago |
I’ve never heard of blotching with tung oil. -- |Statistics show that 100% of people bitten by a snake were close to it.| |
#8 posted 377 days ago |
Pure tung oil will be ok in the bathroom. Tung oil is very water resistant. I would apply about 10-12 coats, just to get a nicer finish. -- Tim-- http://www.tmuli.com |
#9 posted 377 days ago |
thanks for all the help mirror is going in a bedroom |
| Forum | Topics |
Woodworking Skill Share
8849 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
69 |
Joinery
96 |
Finishing
1600 |
3595 |
15985 |
Hand Tools
2102 |
Jigs & Fixtures
501 |
Wood & Lumber
2911 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2778 |
LumberJocks.com Site Feedback
1553 |
Coffee Lounge
6136 |
