Used motor ideas
Forum topic by americanwoodworker posted 06-03-2012 09:53 PM 880 views 0 times favorited 6 replies Add to Favorites Watch
View americanwoodworker's profile
americanwoodworker
185 posts in 2370 days
06-03-2012 09:53 PM
I have 3 motors that are used for blowers for those giant blow up toys. There are no specs on them such as speed or horsepower. Only thing I can find is that two of them are 5.5 amp and one that is 3 amp. I am guessing there is virtually no horsepower. Just enough to run an 10” impeller.
I thought about using them for some sort of dust collection but I cant get much suction from the impeller design. Then I thought about a sharpening system but they turn way to fast.
So does anyone have any ideas as to what I could use these for in the woodworking realm?
-- Your freedom to be you, includes my freedom to be free from you.
View knotscott's profile
knotscott
8012 posts in 3372 days
#1 posted 06-03-2012 09:57 PM
You could gear it down for a sharpener. You might be able to use one for a small DP or maybe a small compressor. You’d need at least twice that amperage for DC, jointer, TS, etc.
View Dallas's profile
Dallas
3599 posts in 2483 days
#2 posted 06-03-2012 09:58 PM
5.5A @ 120V is about 7/8 HP.
You can slow a motor with pulleys and shafts, or if they are universal motors a rheostat.
There are a lot of uses for them, considering what you may not have considered yet.
americanwoodworker
#3 posted 06-03-2012 10:20 PM
Well I do not believe I can use a rheostat on this one. This 5.5 one I have is a capacitor start which I believe cannot be slowed down without burning up. But I am by far an expert in this area. If I can plug it in without getting shocked, then I will call that an educated guess…lol!
Dallas
#4 posted 06-03-2012 10:29 PM
Then use a series of pulleys and belts to get it to the speed and/or power you want.
In the US, 1725 and 3450 rpm are going to be the standard.
Everything, (mostly) is adapted from those ratings.
View dhazelton's profile
dhazelton
2767 posts in 2293 days
#5 posted 06-03-2012 10:37 PM
A very small lathe is all I can think of.
View Adam's profile
Adam
46 posts in 3150 days
#6 posted 06-03-2012 11:53 PM
If you still have the blower for it you could make an air filter for the shop
