Milling 8/4 lumber into 1" and 3/4" thick boards
Forum topic by jeffroL posted 06-03-2012 09:16 PM 1378 views 0 times favorited 5 replies Add to Favorites Watch
View jeffroL's profile
jeffroL
10 posts in 2178 days
06-03-2012 09:16 PM
Topic tags/keywords: milling
Folks, keen to hear thoughts.or tips on how I can make the most use of the lumber I purchased. I need 1” and 3/4” thick boards for the Andirondack chairs project I’m working on. Initially I was hoping to buy 4/4 and 5/4 boards for my 3/4” and 1” thick boards respectively. Afetr a good time searching,I find that most lumber suppliers only offer 4/4 and 8/4 thick Spanish cedar.
I’m going to try to get 1” and 3/4” boards out of these 8/4 boards, by resawing and milling. I realize it is cutting it fine…..pardon the pun. Does anyone have thoughts or tips for me?
Many thanks in advance.
Jeff
5 replies so far
View Infernal2's profile
Infernal2
107 posts in 2073 days
#1 posted 06-03-2012 09:55 PM
Are you doing this by hand or using machinery?
jeffroL
#2 posted 06-03-2012 11:53 PM
Infernal2: I’m using my bandsaw, jointer and planer.
View killerb's profile
killerb
150 posts in 2274 days
#3 posted 06-04-2012 12:32 AM
Not saying it will not happen, but it will be hard. If you want to make those chairs, why not cedar or cypress? Much easier to get and less costly. bob
-- Bob www.bobkloes.com
View Milo's profile
Milo
869 posts in 3195 days
#4 posted 06-04-2012 12:40 AM
This will sound silly after your follow up not, but..
Bandsaw, then join, then plane.
Leave a little waste at the bandsaw stage, length and width, and do your final cuts to length after e planing stage.
Good luck!
Milo
-- Beer, Beer, Thank God for Beer. It's my way of keeping my mind fresh and clear...
View jmos's profile
jmos
809 posts in 2246 days
#5 posted 06-04-2012 11:43 AM
I’ve done similar thing before, resawing 3/4” stock to get panels for shiplapped backs. Usually works well. I would suggest jointing a face, thickness planing just enough off the other face to get it nice and flat, jointing the edges, and then resawing. This way you’ll end up with already jointed faces on the resawn boards, so they can be thickness planed to clean up the cut face and reduce to the thickness you’re looking for.
As Milo said, leave some excess; unless your bandsaw is perfectly tuned you’ll likely have to do some cleanup on the cut face.
Also, don’t be surprised if you get some movement on either piece. I’ve had a few freak out on me; probably not completely dry.
-- John
