Table saw question
Forum topic by Iggles88 posted 06-03-2012 05:42 AM 2049 views 0 times favorited 28 replies Add to Favorites Watch
View Iggles88's profile
Iggles88
247 posts in 2327 days
06-03-2012 05:42 AM
Im having the same problem that it seems a lot of people hve, when I raise the blade it changes the alignment by way too much. My saw is a jet proshop. From what I’m reading this is going to be a tough fix if it can be fixed at all, what I just checked and found out is that I bought my saw on march 12 which means of I’m going to return the saw I have 10? More days, looks like I have a decision to make, I like the saw but this issue has to be taken care of. If this was your saw would you go through the hassle of having it repaired or just return the saw and either get another pro shop or buy a different saw. Please I appreciate all advice but I’m not looking for recommendations on what saw to buy if I do get a different one because I can’t get a cabinet saw I don’t have 200 available in the shop. Im looking for advice on how to remedy this problem
28 replies so far
View MrUnix's profile
MrUnix
6592 posts in 2165 days
#1 posted 06-03-2012 05:52 AM
I’d call the place where you bought it, describe the problem and see what they have to say first. If they don’t give you a satisfactory answer, then escalate up the food chain :)
View dhazelton's profile
dhazelton
2755 posts in 2262 days
#2 posted 06-03-2012 12:14 PM
Does it change the blade angle, or is the blade not perpendicular to the cut? If your saw has a trunnion bolted to the table it can be shimmed ion the opposite side of the blade tilt. If the blade isn’t perp to the cut you’d have to undo all the bolts and that hold it to the table and whack away accordingly.
View Charlie's profile
Charlie
1100 posts in 2252 days
#3 posted 06-03-2012 12:54 PM
If it’s changing as he raises or lowers the blade, it’s an issue in the blade height adjustment mechanism. I would definitely call the place I bought it from and explain the problem as a first step to see what remedy options you have. If it’s something that needs a repair or parts replacement, AND if you really like the saw, it might be worth the time. Otherwise, I’d take it back. If you have the jps-10ts, I think it’s made in Taiwan probably where a lot of other saws are made for other manufacturers. Table mounted trunions? I had the same issue on a Rigid R4512 and ended up taking it back. Raise blade and the back of the blade would shift to the right by over .012. Lower the blade and it shifts back to the left. The amount of shift was not consistent so it was impossible to find a “sweet spot”. Too bad. I really liked that saw. I now have a Steel City 35990G with cabinet mounted trunions. MUCH easier and no alignment problems.
Iggles88
#4 posted 06-03-2012 07:31 PM
What i found last night was that when I raise the blade it moves to the left doesn’t tilt the blade at all, however when I lower it the blade goes to the exact spot it was before raising it. Basically when I lower the blade it goes back into alignment so what I need to do for now is raise the blade above where I want it and lower it to the height I need it. Inconvenient and I’m definitely going to get it looked at but atleast I can use the saw until that does happen. I’m not sure what to do if they say they can’t have a tech come out. I can’t take it to a service center and from what I understand jet doesn’t take returns on their tools and acme tools where I bought it needs the original box and a few other things. I obviously threw the box out after I seen the saw was working good in the beginning.
View spunwood's profile
spunwood
1202 posts in 2802 days
#5 posted 06-03-2012 07:35 PM
yikes. my ts is not set well when the blade has been lowered…it can have play in it. rather, I always try to raise it to the needed height. there is no play in height when raising for me. So I would be concerned about maintaining the proper height doing what you do, but then again you are trying to compensate for a whole other issue.
good luck
brandon
-- I came, I was conquered, I was born again. ἵνα ὦσιν ἓν
Iggles88
#6 posted 06-03-2012 07:40 PM
Brandon I’m not sure what you mean could you try to explain a different way?
View Cato's profile
Cato
701 posts in 3278 days
#7 posted 06-03-2012 11:59 PM
If it is a new jet table saw it is under warranty for 5 years.
You could call their customer support and see if they can send a tech to look at it and see if they can fix it.
I know of another instance where this happened on a new jet table saw and jet replaced the saw in less than two weeks.
View toolie's profile
toolie
2120 posts in 2594 days
#8 posted 06-04-2012 11:34 PM
iggles88…....it’s a jet, so we know you overpaid for what you got. return that overpriced underperforming saw and look at steel city or grizzly if new is what you want. jet and powermatic are never rated a top tool in comparative tool rests, so get out before your mistake becomes irreversible. if used is a possibility, and jet is what you want, find one at least 20 years old. the new ones are shodows of their former selves.
Iggles88
#9 posted 06-05-2012 12:34 AM
Toolie…..I appreciate your opinion but I don’t think I’m going to return my saw. It performed great before this incident and I haven’t exactly heard great things about steel city Or grizzly either. No matter what every manufacturer is going to have problems with a few tools here and there. it’s how thy handle it that I really care about and after talking to her today they are sending someone out to my shop and if the saw cant be fixed they are going to replace it. To me that’s great service and what they should do to fix their mistake. Like I said I appreciate your opinion but there will be a ton of people who have the complete opposite opinion but to each his own. We can only do what we ourselves are happy with.
spunwood
#10 posted 06-05-2012 12:53 AM
Thought this may have little to do with your problem, this is what I have experienced and I know that it is not uncommon:
When setting blade height, I may crank it too high.
Then I lower it, but it is not ‘set’ in place.
Rather, it can be pushed down a bit still.
When raising the blade it does not do this.
If I remember correctly, it has to do with the kind of mechanism certain saws use for adjusting the blade height.
Again, this is not what you are experiencing, so maybe I am just jabbering.
Best of luck,
brandon
Iggles88
#11 posted 06-05-2012 01:17 AM
Brandon, it sounds very close to what I’m experiencing but luckily at this point it’s out of my hands, if jet can fix my saw and have it working the way it should I’ll be more then happy and if not they’re going to replace the saw which I wouldn’t mind because I’d have a nice brand new saw to work with.
View Ted's profile
Ted
2838 posts in 2177 days
#12 posted 06-05-2012 02:09 AM
I have this problem with my cheap Ryobi table top saw, and also on a cheap Delta that I burned out some years ago, but I would not expect (or accept) this from anything that cost over, say, $300. If I’m reading right, the blade tilts slightly as it’s moving up or down, but if I take it a little higher (or lower) it moves back into position. What I do is raise (or lower) it a little more until it tilts back to where it should be.
I think in the case of my cheap Ryobi and the deceased Delta, the threaded rod that the cheap plastic turn crank turns is bent. I deal with it and adjust accordingly but, like I said, had I paid more than a few hundred for the saw, that would not be acceptable. I would take it back.
-- You can collect dust or you can make dust. I choose to make it.
Iggles88
#13 posted 06-05-2012 01:31 PM
Ted, I agree with you there’s no way I was just going to let it go I was just seeing of anyone else was ever able to fix the issue because I like the saw and didn’t want to get rid of it. They’re sending a tech out I’m guessing I’m going to get my saw replaced I don’t see how they’ll fix what’s going on with it
toolie
#14 posted 06-05-2012 07:39 PM
iggles88…....what’s your plan should the problem reoccur once the warranty has expired?
Iggles88
#15 posted 06-06-2012 05:31 AM
The warranty is 5 years away and after 5 years that could hapoen to anyone, if the saw works right for 5 years then stops working then I probably did something to help it break.. I don’t see that being an issue
showing 1 through 15 of 28 replies
