what have I done wrong this time
Forum topic by skidiot posted 06-03-2012 03:53 AM 1804 views 0 times favorited 22 replies Add to Favorites Watch
View skidiot's profile
skidiot
73 posts in 3644 days
06-03-2012 03:53 AM
Topic tags/keywords: question
I am trying to make a solid wood table top. It is made of six 5” wide boards. I did two, 3 board glue ups. these went together with no problems. The boards were all jointed perfectly, I didnt have to use any clamp pressure to get them to come together. I then tried to put the two 3 board units together. They seem to now have a convex bow in all 4 edges. I have tried to rejoint them with no success. There is no way to pull the bow out of a 15” wide piece of white oak. What have I done wrong, and is there a way to fix it. I hate wood working.
-- skidiot northern illinois
22 replies so far
13604 posts in 3340 days
#1 posted 06-03-2012 04:04 AM
lay a longer straight ply or solid wood up against the fence
(it needs to be parallel )
and move the whole thing over and rip the boards one side
if there is a concave in the other side
it will still ride true after the saw fence
then after both wider assemblies are straight on one side
take off the secondary fence
and rip them regular
with your new straight edge against the saw fence
View waho6o9's profile
waho6o9
8191 posts in 2576 days
#2 posted 06-03-2012 04:17 AM
Maybe, alternate your pieces like this if you haven’t already done so, if I understand your situation correctly.
#3 posted 06-03-2012 04:24 AM
this is an exaggerated version of what i mean
View PurpLev's profile
PurpLev
8535 posts in 3648 days
#4 posted 06-03-2012 04:25 AM
when you clamped the boards together – were all the clamps on the same side of the glue up? or did you alternate one clamp above, one clamp below ?
if all clamps are above (or all are below) then you can introduce a pulling action towards one direction which can trigger a bow in the final panel. you should alternate clamps.
Gerald Thompson
940 posts in 2234 days
#5 posted 06-03-2012 12:11 PM
I use clamping cauls on all panel glue ups. They are easy to make and save a lot of time and frustration.
Googel Mike Henderson and look @ his pictorial.
-- Jerry
skidiot
#6 posted 06-03-2012 01:19 PM
Is it possible that the water in the glue made the middle of the boards swell up slightly creating the bowing? I am going to let them sit for a while and see what happens.
waho6o9
#7 posted 06-03-2012 01:57 PM
Maybe post a picture of your panel skidiot.
View Lee Barker's profile
Lee Barker
2170 posts in 2850 days
#8 posted 06-03-2012 02:25 PM
The original post is not real clear to me.
The procedure Patron so vividly shows is to remove hook.
You said “bow on all four edges.” Could you clarify that?
We’ll find out if cauls or opposing clamps have anything to do with the solution.
Kindly,
View Howie's profile
Howie
2656 posts in 2922 days
#9 posted 06-03-2012 02:32 PM
I would be highly suspicious of a high moisture content in the wood.
If it is hook like Lee says, then Patrons fix is the ticket I would think. These two guys know what they are talking about.
-- Life is good.
skidiot
#10 posted 06-03-2012 06:10 PM
Its actually the opposite of what Patron showed. The long edges are bowed out.
Howie
#11 posted 06-03-2012 06:13 PM
Guess I’m like Lee,I’m not following when you say “long edges”.
-- Life is good.
View A Slice of Wood Workshop's profile
1072 posts in 3173 days
#12 posted 06-03-2012 06:27 PM
So it is leaning towards more a a circular shape?
-- Follow me on YouTube- http://YouTube.com/user/asliceofwoodworkshop
#13 posted 06-03-2012 07:02 PM
then fix a board to one edge
(with double tape or brads)
and run it thru the saw
sorry for the mis-read
in the middle of the night
thought i had read concave
skidiot
#14 posted 06-03-2012 09:14 PM
Right. Its not very much about 1/16th but enough to make a visible gap.
Lee Barker
#15 posted 06-04-2012 02:36 PM
So when you put the two pieces together, the edges you want to join, they touch at the center but are gapped at the ends.
The fix is to joint both edges straight. You say you tried that with “no success.” This suggests a jointer setup problem, yet the boards jointed fine individually.
Overclamping the first set of glueups didn’t happen.
Moisture is not a logical culprit.
It is a mystery. But solvable.
What actually happens when you attempt to joint them? How long is your jointer bed? How long are the glueups?
Kindly,
