| Forum topic by noone | posted 383 days ago | 626 views | 0 times favorited | 8 replies | ![]() |
383 days ago |
I only have a 1/4” shank router right now and I need to route two 3/4” wide tracks in my workbench for a crosscut sled to slide into. I know I can buy a 1/2” shank 3/4” dado bit, but that would require me buying a new bit and a new router. Is there some other way I can create this 3/4” wide 1/2” deep cut? |
8 replies so far
#1 posted 383 days ago |
When I did mine, I clamped guide boards to my workbench and routed a 1” wide slot that went far enough into the bench to allow the sled to clear the blade. I went to 1” so the sled runners wouldn’t get hung up if the bench or saw moved. -- Adversity doesn't build character...................it reveals it. |
#2 posted 383 days ago |
What 1/4” shank bit do I use to route a 1” wide slot? Just a straight router bit and move it around between the two guides to remove all the material? |
#3 posted 383 days ago |
Just use a guide board or straight edge and route with you 1/4” shank router bit but only cut half way down using two passes this will cause a lot less stress on your router bit. If you don’t have a 3/4” router bit just move the fence after the first two cuts so that your router bit cuts you 3/4” groove. -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#4 posted 383 days ago |
Clamp your guideboards at the desired distance apart and use them to get straight sides then freehand the rest. I still encourage wider slots in your workbench. If the bench or saw move a little, the sled won’t travel all the way. The directional support for the sled runner is the saw miter slot. The workbench slot(s) just allow full sled travel. -- Adversity doesn't build character...................it reveals it. |
#5 posted 383 days ago |
Agree with sawkerf. You could also cut 3/8” off your workbench |
#6 posted 383 days ago |
If I was you, I would buy a 3/4 inch router bit. It will come in handy in the long run for many other projects. Layout your grooves where you want them. Measure from where the edge of the router bit meets the outer line to the edge of your router base. Rout your groove in two or three passes. Then move you straight edge so the router bits will cut the same amount past the other mark. Repeat above steps. Search You Tube. There are a lot of router video how to do its! I have that very task ahead of me when I finish making my table. -- Handcrafted by Mike Henderson - Channelview, Texas |
#7 posted 383 days ago |
This probably isn’t the answer you are looking for but I just raised my tablesaw 1/2” above my bench to provide clearance for the sled runners. Works well for my purposes. -- " I'll try to be nicer, if you'll try to be smarter" gfadvm |
#8 posted 383 days ago |
Search Projects for “Dado Jig” – there are several versions consisting of two guide parts that can be set to the desired dado width. You move the router back and forth guided by the jig, using a bit smaller than the desired width (it is easiest if the bit is more than half the final width, but will work with a smaller bit). I’ll agree with sawkerf and others that the dado in your table should be wider than the tracks in the table saw. -- Peter |
| Forum | Topics |
Woodworking Skill Share
8848 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
69 |
Joinery
96 |
Finishing
1600 |
3595 |
15984 |
Hand Tools
2102 |
Jigs & Fixtures
501 |
Wood & Lumber
2911 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2778 |
LumberJocks.com Site Feedback
1553 |
Coffee Lounge
6136 |
