Speed control for 1" belt sander?
Forum topic by Lee Barker posted 06-01-2012 08:34 PM 1133 views 0 times favorited 3 replies Add to Favorites Watch
View Lee Barker's profile
Lee Barker
2170 posts in 2783 days
06-01-2012 08:34 PM
I have one of these, the kind with the outboard 5” disc sander.
Mine has no badging but if it’s like all the other clonettes, it’s 1/3 hp, 3450 rpm, 1100 watts.
Is it possible to put some kind of speed control on this? I need to slow it down for some very precise work on the disc sander.
-- " his brain, which is as dry as the remainder biscuit after a voyage, he hath strange places cramm'd with observation, the which he vents in mangled forms." --Shakespeare, "As You Like It"
3 replies so far
View Sawkerf's profile
1730 posts in 3001 days
#1 posted 06-01-2012 09:07 PM
Depending on the type of motor it has, a router variable speed controller might do the job. A call to the manufacturer should give you the needed motor info.
-- Adversity doesn't build reveals it.
View Loren's profile
10096 posts in 3581 days
#2 posted 06-01-2012 09:33 PM
I think not. You might take the head off a drill press,
clamp it to a bench, chuck a 5” paint stripping disk into
it, and rig up a table.
I mean, you could figure it out with the sander but it
would be a lot of hassle I think. The sideways drill
press trick would take about 1/2 an hour to put together.
View Dusty56's profile
11819 posts in 3621 days
#3 posted 06-01-2012 10:13 PM
The Router speed control is meant for motors with brushes. If you have one already , give it a whirl : )
