Air compressor filter / water separator recommendations?
Forum topic by Vrtigo1 posted 353 days ago 3552 views 0 times favorited 6 replies Add to Favorites Watch
View Vrtigo1's profile
Vrtigo1
420 posts in 1159 days
353 days ago
I was recently spraying a project using my trusty HF spray gun and I noticed that it had developed a small air leak where the gun connects to the hose and some water was coming out of the hose at that area. I started looking at filters on amazon and gather that there are filters that take out particulates and there are filters that take out moisture, and I guess I probably need to get both. Prices ranged all over the place and none of them really had consistently good reviews.
I also saw something in one review about moisture separators not being effective unless they were mounted a good distance away from the compressor because if you connect it right at the compressor the air is too hot. I have a retractable hose reel mounted to the wall right above my compressor and it only has a very short (i.e. 3’) hose that connects it to the compressor, so I have to mount the filters right next to the compressor.
I only spray occasionally, most of the time I am using the compressor to run a brad nailer or blow off nozzle. Looking for any recommendations on filters / filter setup.
Also, I know you’re supposed to periodically empty the compressor to get rid of the water that builds up inside, but I’ll admit that I haven’t done that in over a year. There’s only a couple inches of clearance at the bottom so it’s impossible to get the water to go anywhere but all over my garage floor, and the compressor is so large and heavy it’s not really practical to move it outside to empty it. How do others handle emptying the water from stationary compressors?
View Tennessee's profile
Tennessee
1089 posts in 682 days
#1 posted 353 days ago
Most people I know who have stationary compressors take the time to release all the air, take out the drain valve, put in a close nipple, a 90’ and then a longer pipe with a valve on it to get the drain out from under the tank. Black pipe will work. Use a ball valve. Crack the valve slightly when you drain off the air, and if you don’t have too much pressure built up, 20-25 lbs., you can use a gallon milk jug to catch the water with the valve just cracked.
If you have not drained your compressor in a year, depending on where you live and when you run your compressor, you could have multiple inches of water in there.
If you have a fair sized tank, you can put the filters fairly close, the air cools pretty quick inside the tank. My last filter seperator kit was mounted no more than a few inches from the outlet on a thirty gallon tank, and it ran fine. I believe you can also get them from HF if you look around.
-- Paul, Tennessee, http://www.tsunamiguitars.com
View cracknpop's profile
cracknpop
79 posts in 517 days
#2 posted 353 days ago
In the humid Midwest, water in the air compressor can become a much bigger problem when spraying a finish. Drawing from my experiences growing up in an auto body shop… I regularly drain the tank on my compressor (easier to wipe water from the floor than sanding it out of the finish coat).
I also have a 30’ air hose connected to an air filter similar to this one ( http://www.lowes.com/pd_221014-47120-SGY-AIR9_4294813345_4294937087_?productId=3414724&Ns=p_product_qty_sales_dollar|1&pl=1&currentURL=%2Fpl_Air%2BTool%2BAccessories_4294813345_4294937087_%3FNs%3Dp_product_qty_sales_dollar%7C1&facetInfo= ) that I will plug into the 50’ air hose attached to my compressor. Mount the air filter higher than your compressor if possible (harder for water to flow up hill). I only use this hose and filter for spraying.
While trying to finish a large project when the humidity was particularly high, I coiled the hose from the compressor to the air filter into a cooler packed with ice to help condense any moisture in the air line before it reaches filter. May be a little overkill BUT… I have NO water in my spray finishes.
If this set up ever starts to fail, I have another filter canister that holds a whole roll of toilet paper to catch any moisture in the air line… but for now, the toilet paper stays in the bathroom.
Hope this helps.
-- Rick
View dbhost's profile
dbhost
4748 posts in 1400 days
#3 posted 353 days ago
For starters, you need to drain that water from the tank. You will ruin finishes as well ans pnuematic tools shoving wet air at them…
Like was mentioned above, remove the drain valve, and install a short radius street elbow, and then a piece of pipe / nipple long enough to get out from under the tank, then install a ball valve. Not sure what the problem is with spitting water on a garage floor, but just let it go. If you HAVE to keep it off the floor, plumb the drain all the way outside and blow the water / air into a flower bed or something…
View pintodeluxe's profile
pintodeluxe
1739 posts in 981 days
#4 posted 353 days ago
I use an in-line water trap at the compressor. I purchased it at a local hardware store for $10. It has lasted 15 years and counting. I drain my compressor after each use to prevent water from building up, and I have never seen water contamination while spraying finishes.
Good Luck!
View gfadvm's profile
gfadvm
6625 posts in 858 days
#5 posted 353 days ago
Placing an inline water trap at the compressor did not work for me (I think because the air exiting the compressor is too hot for the water to condense). Next, I strongly encourage you to drain your compressor often for 2 reasons: to keep water out of your airtools and spray; second, to keep your pressure tank from rusting out and exploding! I plumbed mine to the edge of the base where I could get to the valve easier and then connect a piece of tubing to drain water away from the compressor.
Vrtigo1
#6 posted 332 days ago
Sorry to bring up an older thread. I ended up plumbing in one of the standard hardware store air/water filters about 10” from the outlet on the compressor and this seems to be working well. I can’t believe I didn’t think to also plumb a line from the drain to get it out from under the compressor (duh!), so I will do that as well. When I put in the filter I also drained the tank and it had maybe a cup to a cup and a half of water in it which was less than I expected. The reason I didn’t want to dump water on the garage floor is I expected it to be rusty and didn’t want to stain the concrete. Thanks for the tips they were very insightful.
