What is the best way to route a 1/8" wide groove for a Garden Hod
Forum topic by Allanwoodworks posted 06-01-2012 03:28 AM 3902 views 0 times favorited 6 replies Add to Favorites Watch
View Allanwoodworks's profile
Allanwoodworks
112 posts in 3043 days
06-01-2012 03:28 AM
Topic tags/keywords: garden hod router bit
Hello,
I am building a garden hod for my wife for her new garden. If you look at the picture of this one I found on Google images, you can see the groove for the wire to go into. The wire is 1/16” thick and fairly ridged. My idea is to get a 1/8” bit and use either my hand router or router table and set the fence at say 3/8” and just route the groove working my way around the rounded corners till I reach the other side. My question is this safe or should I do it with my hand held router with the fence on it set to 3/8”? Should I get an upcut or downcut spiral bit? Any info you provide will be greatly appreciated.
Ty
-- Ty, Up in Washington
View greg48's profile
greg48
610 posts in 2959 days
#1 posted 06-01-2012 03:55 AM
You may wish to consider using a template with a guided bit or bushings. Regarding the spiral bit, you may just want to use a double fluted straight bit and not try to cut to the full depth in one pass. Wow, Jonathan just beat me to the post. His idea works just as well.
-- Greg, No. Cal. - "Gaudete in Domino Semper"
View waho6o9's profile
waho6o9
8523 posts in 2779 days
#2 posted 06-01-2012 03:57 AM
+1 for Jonathan’s fine pictorial.
I’d use a 1/8 router bit and make a couple of passes. Easy peasy.
View davidroberts's profile
davidroberts
1027 posts in 3688 days
#3 posted 06-01-2012 04:03 AM
router table. remove the fence. install a guide pin the distance from the bit that you want the groove from the edge of the board. while the edge is firmly held against the pin, lower the board onto the bit and push the board along the pin around the curves until up get too the stopping point then raise the board off the bit. do other board. done. Upcut bits are better expelling chips from the groove. downcut bits leave a sharper edge but not so good at clearing the groove. If you go slow and make a couple of passes, the downcut bit will make a nicer groove for show. Remember that you always move the board from right to left, against the bit.
-- Better woodworking through old hand tools.
Allanwoodworks
#4 posted 06-01-2012 05:00 AM
Wow, Jonathan that amazing sketch up work! Is there a way I could make a jig to both route the outside edge then add a bushing or a spacer to route the inside groove?
View quartrsawn's profile
quartrsawn
146 posts in 3415 days
#5 posted 06-01-2012 05:31 PM
I would do it with an edge guide and a 1/8 in. down cut spiral bit. The outside edge of the end panel is the shape you need to duplicate.Set the edge guide for the back set you need or add an auxillary fence with a wider piece of wood.
-- Nat - West Sayville,L.I., NY
117328 posts in 3779 days
#6 posted 06-01-2012 06:18 PM
Excellent suggestions and fantastic sketch up work Jonathan. Either approach will work just be very careful to make sure that your pattern does not have any little defects because they will be duplicated in your groove when your route.
