Wavy drawer front
Forum topic by siouxdawgs0409 posted 06-01-2012 01:40 AM 1647 views 0 times favorited 8 replies Add to Favorites Watch
View siouxdawgs0409's profile
siouxdawgs0409
107 posts in 3002 days
06-01-2012 01:40 AM
I am looking at building a drawer with a wavy front design… Similiar to the design on this mirror.
http://www.furnituresupersource.com/vintage-cherry-cheval-mirror/":http://www.furnituresupersource.com/vintage-cherry-cheval-mirror/
Can any one provide some good resources on how to take on this task? Is this a solid piece, veneered?
8 replies so far
View cabmaker's profile
cabmaker
1696 posts in 2717 days
#1 posted 06-01-2012 01:52 AM
Im just spectulating that the peice in question is veneerd over a wavy substrate. Youll have to do that. You have a bandsaw ?
siouxdawgs0409
#2 posted 06-01-2012 01:55 AM
I do have a band saw.
cabmaker
#3 posted 06-01-2012 02:00 AM
I would mill the drawer front with stacked mdf and radius the front only. The inside can remain flat. There are preferances though like Douglas fir,etc. but you can count on the mdf staying constant with that venner,(I dont think im spelling that right, oh well)
siouxdawgs0409
#4 posted 06-01-2012 02:11 AM
Thanks…I will look into that a little closer. Just starting to get some ideas.
siouxdawgs0409
#5 posted 06-19-2012 03:10 PM
With an mdf as the substrate I would open the drawer and see the substrate on the sides. Plus joinery might be a challenge with mdf joining to the hardwood drawer side. How could this be eliminated? Also with the veneer going to the edges of the drawer would I have to worry about the veneer getting caught as you pull the drawer open and close and eventually separating over time?
View Tennessee's profile
Tennessee
2752 posts in 2422 days
#6 posted 06-19-2012 03:44 PM
I’d bet that the inside is also curved as the front. If you are going to bandsaw the front, why not the inside? And I think I’d use poplar as a substrate, glued up to eliminate grain running in the wrong direction. Lighter than MDF, more period correct, no joint problems. If the last piece where it connects to the sides is 3/4” flat, or 1/2”, you could even dovetail the sides on. Groove in the bottom for the drawer bottom would be tough to get in that inside curve, though. I’d probably rout a dado in the curve and glue and tack the bottom on.
siouxdawgs0409
#7 posted 06-19-2012 04:05 PM
Would not leaving the inside flat make it easier to join and attach a bottom? I do not see a problem with the varied thickness of the drawer front if I radiused only outside.
View Bill White's profile
Bill White
4861 posts in 3868 days
#8 posted 06-19-2012 04:37 PM
Radius outside only will be just fine.
Bill
-- bill@magraphics.us
