Restoring a #78 Rabbet Plane
« back to Hand Tools forum
Forum topic by WoodChuck84 posted 05-31-2012 11:41 PM 1039 views 0 times favorited 3 replies Add to Favorites Watch
View WoodChuck84's profile
WoodChuck84
56 posts in 2896 days
05-31-2012 11:41 PM
Topic tags/keywords: plane
Any tips on restoring a 78?
I’ve got all of the parts (including a modern made fence and depth stop)
The main issue is that I’m having a devil of a time getting everything squared.
-- Hello, my name is Jarrod and I am a woodaholic.
3 replies so far
View chrisstef's profile
chrisstef
17423 posts in 3030 days
#1 posted 05-31-2012 11:58 PM
I havent given my #78 any test runs yet but i flattened the sole on 220 grit sandpaper on glass then to 320. I did the same to the depth stop, adjutable fence and the irons cap (which had factory black paint on it). I sharpened the iron and also learrned along the way that the bevel angle doesnt matter because its a bevel down plane (thanks HOYD thread). I sharpened the iron to 25 degrees. I just finished up the other night and havent put it through any runs yet. unfortunately.
WoodChuck84
#2 posted 06-01-2012 12:28 AM
How do you flatten the sole while maintaining the 90 degree angle relative the the side?
chrisstef
#3 posted 06-01-2012 12:33 AM
I havent flattened the side of the plane just the sole but youre right the side of the plane will need to be flat as well for you to get a crisp 90 rabbet. Id treat it like anything else and lap it with some 220 grit on glass. Id keep a good square close by to check for 90. I almost forgot to take the nicker out when you flatten the bottom, that would be no good.
