How do you drill compound angled holes?
Forum topic by Spratley posted 05-31-2012 10:47 PM 5300 views 0 times favorited 4 replies Add to Favorites Watch
View Spratley's profile
Spratley
5 posts in 2183 days
05-31-2012 10:47 PM
Topic tags/keywords: compound angle drill drill guide stool
A beginner here—I would like to drill a 15/15 degree compound angle with a forstner bit (For a stool). No drill press. . . just an angled drill guide. How exactly can I go about this? Is there a drill guide for sale that allows adjustment on both axes? Or will I have to craft a 15 degree wedge or frame to set the guide on?
View Jeremy Greiner's profile
Jeremy Greiner
568 posts in 2769 days
#1 posted 05-31-2012 11:21 PM
If you already have the drill guide, you can wedges to fasten screw onto the bottom of the drill guide that gives 15 degrees on one axis, then you can use the drill guides angle to give you the 15 degrees on another. This will give you your compound angle.
If you don’t already have your drill guide, and plan on purchasing one, I’d look for a used drill press instead.
-jeremy
-- Easy to use end grain cutting board designer: http://www.1024studios.com/cuttingboard.html
View bondogaposis's profile (online now)
bondogaposis
4727 posts in 2348 days
#2 posted 05-31-2012 11:33 PM
Tilt your table saw blade 15° and then set you miter gauge at 15°. Trim a block of scrap wood. Set the block on it’s angled end next to the hole location and drill it freehand using the edge of the block as a guide for your eyeballs.
-- Bondo Gaposis
117091 posts in 3574 days
#3 posted 05-31-2012 11:39 PM
Take a look on You Tube I think I’ve seen a couple people doing close to what the guys are describing here.
Spratley
#4 posted 06-01-2012 03:57 PM
Thanks for your tips, guys. I don’t trust my hands for the freehand method yet. But I can do the geometry to cut some “footing” blocks for a drill guide.
Thanks again.
