Draw Knife Sharpening
Forum topic by Chris posted 97 days ago 171 views 0 times favorited 6 replies Add to Favorites
View Chris 's profile
Chris
1221 posts in 473 days
97 days ago
Topic tags/keywords: draw knife sharpening
Would any of you fine folk be able to provide pointers on the subject of sharpening a Draw Knife?
I was received a old (well used) draw knife and having never used one have no idea how to begin.
Thanks in Advance!
-- Chris
Chris
97 days ago
Any Takers????
-- Chris
View GaryK's profile
GaryK
8482 posts in 470 days
97 days ago
I just got one from ebay a few weeks ago.
I will be using my Tormek to sharpen it. Haven’t looked into which fixture I will use yet.
View lew's profile
lew
1241 posts in 237 days
97 days ago
Chris
97 days ago
Wow…. Thanks Lew! Nothing like a step by step guide. Anyone else have a different method?
-- Chris
View Quixote's profile
Quixote
101 posts in 120 days
97 days ago
Chris,
My preferrred method ( preferred because I can’t afford a better system…yet…) is to use a Lansky system similiar to sharpening a pocket knife.
Depending on blade width, I lock my guide so I can have a good 3 or 4 inch width sharpening area. I modify my sharpening stroke slightly to a slight arc instead of straight back and forth to keep a consistant edge.
It’s important to tighten the guide down with the same amount of distance from the cutting edge to keep your angle consistant across the width of the blade. Note that you can select a different angle for the guide bar if you want to give your blade a multi angle finish.
You can use the coarse, medium, fine grit stones to achieve your desired finish.
The cariboo blade site is awesome Lew, Thanks for sharing. For me, I have trouble maintaining the consistant angles while using that method. With my Lansky sharpening method, I can set the piece down for a few minutes, hours days etc, and come back and finish right where I left off. I can do this while watching, television though it greatly annoys my wife….
It isn’t perfect but the angles are much more consistant for me with this method.
Q
-- I don't make sawdust...I produce vast quantities of "Micro Mulch."
View Daren Nelson's profile
Daren Nelson
332 posts in 387 days
96 days ago
I just use a benchstone (water stone) like in the link lew gave. Sharpen it just like a pocket knife.
-- Urban logger, http://nelsonwoodworks.biz/
Bookmark And Share This Page
