Big Mistake!
Forum topic by JNP posted 05-31-2012 08:40 PM 1074 views 0 times favorited 8 replies Add to Favorites Watch
View JNP's profile
JNP
113 posts in 2483 days
05-31-2012 08:40 PM
I am nearing the end of a birdseye and walnut jewelry box (mitered corners all around with an open front for drawers) and I wanted to get a head start on finishing the carcass as I was building the drawers. Well, I applied the finish and set the pieces aside to dry.
I guess the sun was perfectly aligned, heated the pieces and the top and bottom are slightly twisted. The back is severely twisted. Any way to correct with clamp pressure? As all the joints are miters, I can’t just plane it out as that changes all of the dimensions.
Any ideas? Can I put the pieces under clamp pressure and hope they come back? Could I sandwich them between two boards and put them in an oven? Anything?
Thanks.
Jeff
-- Jeff
8 replies so far
View SCOTSMAN's profile
SCOTSMAN
5845 posts in 3491 days
#1 posted 05-31-2012 08:49 PM
You could try it in the microwave for a few seconds till slightly warm not cooked LOL then apply pressure with a few clamps and leave to harden-cool but I would advise you to practice this first on some bent scrap so I am not accused of ruining your lovely box..I have actually heard of this working Alistair
View JNP's profile
JNP
#2 posted 05-31-2012 08:54 PM
Thanks Alistair. I’ll give it a try. Maybe a wet towel in the microwave then clamp it to the table saw top?
-- Jeff
View Bill White's profile
Bill White
4856 posts in 3866 days
#3 posted 05-31-2012 09:05 PM
You clamp a piece of damp wood to the TS top and you’re gonna have another problem called rust.
Bill
-- bill@magraphics.us
View JNP's profile
JNP
#4 posted 05-31-2012 09:07 PM
Ridgid 4511 Granite :-)
-- Jeff
View Don W's profile
Don W
18606 posts in 2473 days
#5 posted 05-31-2012 09:19 PM
good luck. I think your toast. But I have had success flipping the piece over and putting it on wet grass in the sun. A combination of the sun on the opposite side and the dampness may bring it back. I’m not sure how often I’ve used this technique, but if I had to pull a number out of my a%$, I’d say it works about 25% of the time.
Watch it. There is nothing more frustrating than finding out it had worked but you over did it.
View JNP's profile
JNP
#6 posted 05-31-2012 09:32 PM
Well it is cooling now. 5 minutes w/a damp rag and now clamped down. This is for a graduation party Saturday! I don’t think I could get a finish dried by then…
I’m going to leave it clamped for an hour or so. If it works great and if not it’s to the jointer and planer…arg.
Lesson learned!
-- Jeff
View DrDirt's profile
DrDirt
4421 posts in 3648 days
#7 posted 05-31-2012 09:40 PM
Shellac would be dry by then and more than durable enough for a jewelry box
Lacquer also would be quick
View JNP's profile
JNP
#8 posted 05-31-2012 09:45 PM
Thanks Doc. I have used shellac in the past but can’t remember if I cut it…this finish was going to be tung oil then maybe an arm-r-seal top coat.
-- Jeff
