Arc when turning off dust collector
Forum topic by Morayblue posted 05-31-2012 05:41 AM 864 views 0 times favorited 4 replies Add to Favorites Watch
View Morayblue's profile
Morayblue
1 post in 2094 days
05-31-2012 05:41 AM
I just purchased a grizzly 1029z2 dust collector and find that the switch occasionally shows considerable arc when turning off. Has anyone else noticed this with their 220v tools. I believe it is inductive kickback, however I do not know if it safe on a dc.
View Bill Davis's profile
Bill Davis
226 posts in 3832 days
#1 posted 05-31-2012 12:28 PM
It is fairly typical when interrupting the current (opening a switch) to a load like your DC that an arc will occur across the switch contacts. Properly rated switches are rated to withstand this and thus it likely is no problem. You certainly would not want such an arc to occur in an explosive atmosphere. Wood dust in the air can be potentially explosive but if you search for instances of fire/explosion caused by an arc in a wood dust atmosphere you might find a report of such an incident but they are rare and likely not something to worry about. The arc is not likely to do any harm to the DC either.
View Scot's profile
Scot
344 posts in 3304 days
#2 posted 06-01-2012 12:33 PM
No that is not normal to see an arc. Any arcing should be contained within the switch and not be seen. Check for loose connections, if that doesn’t work contact Grizzly.
-- If the old masters had power tools, they would have used them. So get off your damn High Horse.
4883 posts in 2401 days
#3 posted 06-01-2012 01:17 PM
I have no idea if that’s normal or not, but I do know I don’t see it on any of my tools with mag switches.
View waho6o9's profile
waho6o9
8100 posts in 2484 days
#4 posted 06-01-2012 02:01 PM
Ground it, if I understand the situation correctly.
