help tension on bandsaw
Forum topic by johanna posted 05-30-2012 07:55 PM 889 views 0 times favorited 3 replies Add to Favorites Watch
View johanna's profile
johanna
2 posts in 2423 days
05-30-2012 07:55 PM
Topic tags/keywords: question bandsaw
Hi, I have a 12 inch band saw model number 11324200. I am trying to repair it. I can’t figure out why my tension knob is not working, it won’t tighten or loosen. I took it all apart trying to understand but I’m stuck. Could it just need a new spring? If anyone might know it would be helpful. Thanks
3 replies so far
View AHuxley's profile
AHuxley
874 posts in 3557 days
#1 posted 05-30-2012 08:12 PM
Are you saing the tension know will not turn OR it turns but tension is not added or removed.
johanna
#2 posted 05-30-2012 11:19 PM
It turns but it is not loosening or tightening. Either way you turn it does nothing.
AHuxley
#3 posted 05-30-2012 11:25 PM
Sounds like either the threads on the tensioning rod are stripped or not contacting the nut or the spring is broken or missing.
