gluing tile to pressure treated wood
Forum topic by will delaney posted 05-30-2012 06:32 PM 8480 views 0 times favorited 7 replies Add to Favorites Watch
View will delaney's profile
will delaney
326 posts in 2719 days
05-30-2012 06:32 PM
Topic tags/keywords: question gluing
I just finished building a top for a outdoor table that had a glass top which broke. I would like to glue some tiles that I have along the edge. Can anyone give he some advice on what type of glue or epoxy would work. Thanks
7 replies so far
View ShaneA's profile
ShaneA
7010 posts in 2682 days
#1 posted 05-30-2012 06:39 PM
Silicon is what we use at work to hold tile samples to mdf. Holds well.
View PaulHWood's profile
PaulHWood
438 posts in 2336 days
#2 posted 05-30-2012 06:48 PM
if you are going to tile the whole table, why not just screw some cement board down
-- -Paul, South Carolina Structural Engineer by trade, Crappy Woodworker by choice
View RussellAP's profile
RussellAP
3104 posts in 2370 days
#3 posted 05-30-2012 07:14 PM
Ditto PaulHWood. Pressure treated wood is wet and when you cover it, it stays wet. You need at least some 3/8th plywood over it. Nice looking tile, I hope you post when you get it finished.
View Scot's profile
Scot
344 posts in 3480 days
#4 posted 05-30-2012 07:17 PM
cement board is the way to go. The pressure treated wood will move and crack the grout lines and possibly the tiles.
-- If the old masters had power tools, they would have used them. So get off your damn High Horse.
RussellAP
#5 posted 05-30-2012 07:21 PM
You may also want to use epoxy grout on this when you tile it. The cracks are likely to be more than 1/8 so at least use sanded grout.
will delaney
#6 posted 05-30-2012 07:28 PM
Thanks for the advice. The tile will be just used as a boarder for the two ends. I don’t have enough to go all around. I got these tiles from someone who was doing a demolition on a building from the 1920s.
View BorkBob's profile
BorkBob
127 posts in 2776 days
#7 posted 05-31-2012 12:41 AM
Hi Will,
As long as you stay with the grain, I think silicone caulk will hold the tile and allow for some movement. I will suggest you rabbit a recess so the top edge of the tile is protected. Good luck.
-- Please Pray for Our Troops / Semper Fi / Bob Ross / www.theborkstore.com
