Spraying waterborn finishes
Forum topic by SST posted 05-30-2012 03:58 PM 4792 views 3 times favorited 19 replies Add to Favorites Watch
View SST's profile
SST
790 posts in 4435 days
05-30-2012 03:58 PM
Topic tags/keywords: question
I volunteered to help a friend with some finishing work & rather than do a lot of experimenting, it seems to make sense to look to the collective experience here, first.
He’s built kitchen cabinets & is planning to spray with waterborn (don’t know the brand right now) finish.
I’ve done a lot of spraying, from cars to wood projects, but nothing water based. I’ve got several HVLP guns with fluid tips including .5mm, .8mm, 1.0mm & 1.4 mm.
I’m looking for advice as to a starting point to begin practicing from someone who’s sprayed these finishes including fluid tip size, pressure, product reduction, etc. Thanks
-- Accuracy is not in your power tool, it's in you
19 replies so far
View danriffle's profile
danriffle
73 posts in 3814 days
#1 posted 05-30-2012 04:49 PM
Sorry, Tom,
Haven’t found any water based that work as nicely as the post catalyzed conversion varnish, so we don’t use them.
Dan
View PurpLev's profile
PurpLev
8548 posts in 3889 days
#2 posted 05-30-2012 04:56 PM
I did some water based spraying (very little), but I did not have to reduce the product – used it as-is out of the can (I used general finishes water based clear polyacrylic) with a 1.0mm tip and it worked well for me. spraying techniques are fairly similar to oil/lacquer I presume and you want to spray a healthy thick-looking layer.
View Milo's profile
Milo
869 posts in 3559 days
#3 posted 05-30-2012 05:02 PM
I disagree with Dan. Water based can work JUST FINE, but you MUST be patient with them. They need between 2 weeks to a month to fully cure to your piece. They are fantastically easy to work with, being water based, and a snap to clean up after, and nowhere near as toxic as some other finishes.
I’ve sprayed WB finish before. You’ll want to experiment a bit with the water percentage you add (based on the manufacturers recommendation). Just like anything else, practice.
ALWAYS filter WB finish. You a fine filter.
My HVLP didn’t HAVE pressure settings (your thinking a compressor?), but I used both .5 & 1.0mm tips. Again, I would practice to see which you prefer.
WBF spray on milky. It clears while it drys. You want the constancy be were the grain just starts to blur. NOT a complete white out, and not clear. You can add extra coats as soon as it dries. Another plus for WBF. I advice not trying to go with a single coat.
DO NOT USE steel wool on WBF. Use one of those 3M brillo pads. You always want to rough up the surface you are spraying. WBF bind physically to what you spray it on, it does not “burn” in like traditional finish. Bubbles can be removed easily by gently blowing across the surface with a fan or hair dry (heat setting turned OFF!).
btw, I almost always padded on finish. But then again, I was doing tabletops.
Hope that helps.
-- Beer, Beer, Thank God for Beer. It's my way of keeping my mind fresh and clear...
View SST's profile
SST
#4 posted 05-30-2012 05:24 PM
Good stuff so far…more is certainly welcome.
View killerb's profile
killerb
150 posts in 2638 days
#5 posted 05-30-2012 05:30 PM
I spray both solvent and water base. Good water base products like General finishes poly or endorovar spray like solvent. I have also sprayed some Aqua coat products. The general finishes sprays well and dries in a heavier coat . The aqua coat does well sprayed in a thinner coat. I have also sprayed agaualante by ML Campbell. That sprays like regular solvent base. You should filter any finish you spray. Never had any water base product take 2 weeks to cure. Maybe if you want to rub it out, you need a week . I spray with a 1.5 tip in one gun and a 1.4 in another. I use 1.0 for shellac. Good guns should spray water base the same as solvent. Hope this helps. bob
-- Bob www.bobkloes.com
Douglas Bordner
4035 posts in 4304 days
#6 posted 05-30-2012 10:49 PM
And there are pre-cat lacquers and varnishes available as waterborne,
boatloads of info here. I have never had to wait more than three days to rub out, and indeed have sanded to flatten for next coat within hours.
Definitely avoid steel wool. I usually first pad on some Zinnser SealCoat 2lb cut shellac to avoid grain raising with the finish coats and to impart a bit of the warmth one gets from nitrocellulose.
I have a Porter-Cable conversion gun with a 1mm nozzle/needle, and spray Target EM6000 right out of the jug (filtering of course) and my compressor is just the PC pancake model. I started out using ML Campbell MagnaLac, but being a home shop guy I was always nervous about the fuel-air bomb I was creating without a spark-proof fan to clear the shop. I’m totally sold on waterborne now.
Best of luck!
View NiteWalker's profile
NiteWalker
2738 posts in 2817 days
#7 posted 05-31-2012 12:14 AM
I spray waterbornes exclusively, more specifically, crystalac super premium. It sprays beautifully, levels nicely and dries very fast. It does not require 2+ weeks to fully cure; it only needs 72 hours.
I spray it with a Qualspray QS-125WB gravity gun, pressure at the gun @29 psi with a 1.2mm tip.
View FreshSawDust's profile
FreshSawDust
68 posts in 2570 days
#8 posted 05-31-2012 12:42 AM
I have had good results with General finishes polyacrylic and Zar Aqua. Both sprayed full strength through the 1.4 tip in my HF gun.
-- TJ - Perryville, Missouri
View KarenW's profile
KarenW
131 posts in 2428 days
#9 posted 05-31-2012 01:09 AM
Having done this for 30 years I prefer a straight lacquer or a pre-cat lacquer for most of the pieces I do. Occasionally I have to use a WB product (due to customer preference) with a 1.5 tip and a bit lower pressure. Never had to reduce, never had to do anything special except to remember to go a little lighter on coats than I would with pre-cat. Oh, I always use an extra coat for good measure.
And I prefer General Finish though I’ve just done a couple pieces with the Rustoleum WB poly and found it adequate.
-- Happiness does not come from doing easy work but from the afterglow of satisfaction that comes after the achievement of a difficult task that demanded our best. --Theodore I. Rubin
117419 posts in 3817 days
#10 posted 05-31-2012 01:32 AM
I prefer water borne finishes I guess I’ve shot them for years so I don’t feel their that much different than any other material .In my experiance none of them I’ve ever used has taken 2 weeks to dry ,that sounds like BLO not water borne, most of them can and must have the second or third coats applied within 2-6 hours, and can be buffed in 12 hours or less. I also like water base material because it’s fumes are far less toxic then oil base material and your gun cleans up with water,no expensive smelly solvents . I would suggest just shooting some on some cardboard before shooting your friends project.
NiteWalker
#11 posted 05-31-2012 01:42 AM
+1 on practicing on cardboard.
Also, I didn’t mention it but I spray full strength too; no thinning.
The crystalac I mentioned, the recoat time is about 30 minutes.
KarenW
#12 posted 05-31-2012 01:42 AM
Thumbs up to the cardboard suggestion!
That’s how I started when I made the move from all hand applied to shooting.
View David Grimes's profile
David Grimes
2078 posts in 2880 days
#13 posted 05-31-2012 02:22 AM
Glad to hear some good things about the Crystalac as I have a gallon that is about to get used. Does it buff out and behave like lacquer when dry ? How is it with very fine (1200 to 8000 grit) wet sanding after cured ?
-- If you're going to stir the pot, think BIG spoon or SMALL boat paddle. David Grimes, Georgia
View SST's profile
SST
#14 posted 05-31-2012 02:57 AM
Thanks to all for the input. As always, this site/forum is such a great resource on all things woodworking. -SST
NiteWalker
#15 posted 05-31-2012 03:56 AM
David, I haven’t done any buffing, but according to the instructions it can be after 72 hours.
It’s good stuff.
