Wetland CNC Build
Forum topic by rawdawgs50 posted 05-30-2012 01:51 PM 4456 views 15 times favorited 43 replies Add to Favorites Watch
View rawdawgs50's profile
rawdawgs50
82 posts in 3015 days
05-30-2012 01:51 PM
I supposed some of you might be interested in seeing this so I am filming a bit as I bring it to life.
This is a 4’x5’ CNC Router that will have a rack and pinion setup. If all goes as planned, it should prove to be a big help to production and allow me to take on jobs that were to time consuming before.
I have quite a few months of research and design and parts selection into this….it should work as planned…if not, I am committed to making it work as planned. A little revision along to way never hurts.
My two goals were to build a machine around my wood working needs first and then for a cost of less than half of what it would be to buy one this size. It is not inexpensive to build this, but very cost effective when looking at the alternative.
My benchmark for a good CNC for my needs is the ShopBot. While this one will not have all the bells and whistles…its the accuracy I am aiming for.
Video Here:
http://www.youtube.com/watch?v=WGZvk1RVWXA&feature=g-upl
-Jason
Wetland Wood Works
43 replies so far
View helluvawreck's profile
helluvawreck
31076 posts in 2865 days
#1 posted 05-30-2012 03:41 PM
I’m an engineer, machinist, woodworker, and Jack of All Trades (master of none). I’m mostly just a glorified Shade Tree Mechanic. I’ve thought about building one of these off and on for a long time. I’m going to favorite this so I can keep up with it if you don’t mind. I wish you the best of luck on it. Thanks for posting.
helluvawreck
https://woodworkingexpo.wordpress.com
View Mainiac Matt 's profile
Mainiac Matt
8044 posts in 2326 days
#2 posted 05-30-2012 05:16 PM
If you’re not registered over at the CNCzone….. there’s a ton of good info and helpfull bot heads over there.
Mach III on a garage sale PC, driving a Geko 540 and NEMA 23 steppers makes a very economical package.
You’ll never push Shop Bot speeds, but micro-steppers will give you all the resolution you could ask for.
I’m 80% done with converting a benchtop mill to CNC (project stalled due to to many committments) and am using this combination.
I program for a CNT 900 sereas at work and though we can run upwards of 900 ipm, we seldom push it that fast. Also, with a shorter machine, you’ll never have straight line moves long enough to accelerate to that speed anyways.
-- It’s the knowledge in your head, skill in your hands and motivation to create in you heart that makes you a woodworker. - Mainiac Matt
rawdawgs50
#3 posted 05-31-2012 01:36 PM
CNCzone is great. That forum helped me a lot from the beginning and I still visit it regularly.
The Gecko G540 and 4 nema 23 motors is the setup on this I am using. Its a little more than others, but it is rated highly for being glitch free. I am not trying to chase electrical demons.
I do not know how fast ipm it will go flat out….but I would not be surprised to see it over 700ipm+ with the gear reduction on the R/P. I am trying to make the gantry as rigid and as light as possible. So even a few pounds less than normal can have a huge affect on acceleration/deceleration.
But like I mentioned before…I will not mind speed…but its accuracy and repeatability I really care about.
rawdawgs50
#4 posted 06-03-2012 12:58 AM
Video 2 is now up
http://www.youtube.com/watch?v=OuYs0ruyKB0
This video just gives insight into the mechanical parts being used, which will become more apparent in subsequent videos. This way it is easier to know what the different components were when you see them.
Also I was so impressed with some new drill bits I purchased that I thought it should be included in the video as well. Maybe you all have experience wit these types of bits, but its the first time I have used them…and after all these years drilling odd metal jobs with my wood working bits…I am again a believer in the right tool for the job. These are made to drill stainless steel and they did not even break a sweat on my 1/4” cold rolled steel.
rawdawgs50
#5 posted 06-10-2012 04:18 AM
View wildbill001's profile
wildbill001
111 posts in 2640 days
#6 posted 06-10-2012 04:32 AM
How are you attaching the 1/4” steel to the plywood?
Bill W
-- "You can tell the pioneers by the arrows in their back" -- Unknown
rawdawgs50
#7 posted 06-10-2012 04:45 PM
There are 3 different possibilities.
Threaded holes
Threaded inserts
Lag screws
View SASmith               's profile
SASmith
1850 posts in 2985 days
#8 posted 06-10-2012 05:28 PM
Thanks for posting the videos.
I am enjoying following along.
-- Scott Smith, Southern Illinois
rawdawgs50
#9 posted 06-13-2012 12:56 AM
rawdawgs50
#10 posted 06-14-2012 11:22 PM
wildbill001
#11 posted 06-15-2012 01:28 AM
Other than maybe you don’t have a kreg jig, is there any reason why you didn’t use pocket-holes for the frame assembly?
Really like the looks of things so far. Keep ‘em coming!
rawdawgs50
#12 posted 06-15-2012 01:57 AM
I did not to use the kreg for the base because dowels do a much better job at alignment imo. You could use a kreg, or both. Also the way I designed the base frame, the reveal of the leg would not really allow a pocket hole on the back side.
rawdawgs50
#13 posted 06-22-2012 11:21 PM
Video 6 up
http://www.youtube.com/watch?v=50ZTG0TJ8_8&feature=plcp
Installing X axis steel and first look at Rack and Pinion.
rawdawgs50
#14 posted 06-29-2012 01:58 AM
Video 7 Up
http://www.youtube.com/watch?v=JLWWu3JNOmI&list=UUtkFlqdY9x6pq8EDk1RGIhQ&index=1&feature=plcp
Design Change on base and 3d model. Now pocket hole joinery is an option
Also
CNC….meet Color
rawdawgs50
#15 posted 07-22-2012 11:20 PM
showing 1 through 15 of 43 replies
