Vise advise
« back to Hand Tools forum
Forum topic by Boatman53 posted 05-30-2012 02:53 AM 3511 views 0 times favorited 14 replies Add to Favorites Watch
View Boatman53's profile
Boatman53
1056 posts in 2192 days
05-30-2012 02:53 AM
I really like the threads here where everyone can add their own info onto one thread. I want to see your favorite vise, did you build a vise, share how you did it. I have an old vise that I’m looking for info on so I’ll start. If there seems to be a lull I’ve got several more I can share.
I found this one on Craigslist this past summer. It is a monster. It weighs 80 pounds. The jaws are 12” wide and open a full 18”. The steel of the jaws is an inch thick at the screw and 3/4” at the edge. All pieces except the screw have casting numbers and every part even the screw is hand stamped with a “2” so everything was milled to fit. The screw is a double start and two revolutions per inch. Anybody got any ideas? Even though I just finished a bench I’m starting to design a new bench for this vise. Please add and have fun.
http://i1135.photobucket.com/albums/m628/boatman53/8080aaa0.jpg
http://i1135.photobucket.com/albums/m628/boatman53/13d2c72a.jpg
http://i1135.photobucket.com/albums/m628/boatman53/8518223e.jpg
http://i1135.photobucket.com/albums/m628/boatman53/9acfdd2c.jpg
http://i1135.photobucket.com/albums/m628/boatman53/d5997f37.jpg
-- Jim, Long Island, NY Ancorayachtservice.com home of the chain leg vise
14 replies so far
View Mauricio's profile
Mauricio
7144 posts in 3147 days
#1 posted 05-30-2012 02:59 AM
Jim that thing is a beast!
I’m making mine now, I just finished my first acceptable screw:
I’m planing on making another one to use as the parallel guide on my leg vise.
View PurpLev's profile
PurpLev
8535 posts in 3644 days
#2 posted 05-30-2012 03:26 AM
my leg vise is using a leevalley vise screw and this chop:
And my wagon vise is using the same leevalley vise screw with a grizzly wheel and a maple block:
Boatman53
#3 posted 05-30-2012 03:38 AM
Thanks for posting, I was thinking of retrofitting a hand wheel to a screw on a vise I’m building.
Boatman53
#4 posted 05-30-2012 03:41 AM
Mauricio, how are you cutting the threads? And tapping the nut. Are you going to tap the leg?
Mauricio
#5 posted 05-30-2012 01:07 PM
I should add that I’m following PurLev’s blog on making a wagon vise with the Lee Valley Screw. However, I dont have his metal working machinery or skill so mine wont have a wheel on it unfortunatley.
Jim, I’m cutting the threads with a V cutter on my router with a jig I made following Carter’s instructions here. And I am planning on tapping the leg directly.
Boatman53
#6 posted 06-01-2012 03:42 AM
It’s too quiet already, so here’s another work holder I put together a couple months ago. It can hold small parts in almost any position. The bolt shaft is 5/8” and will fit in the dog holes in the bench or if I want to be outside I can bolt it on a workmate.
http://i1135.photobucket.com/albums/m628/boatman53/85b72c3b.jpg
http://i1135.photobucket.com/albums/m628/boatman53/0f1bd7f0.jpg
http://i1135.photobucket.com/albums/m628/boatman53/7ae4e2cc.jpg
Boatman53
#7 posted 06-01-2012 03:43 AM
Dang still don’t have this photo thing figured out. Sorry I’ll try reposting them tomorrow.
View cabmaker's profile
cabmaker
1730 posts in 2805 days
#8 posted 06-01-2012 03:50 AM
Very clever Jim, I like it. Is that a swivel base for a wilton baby bullet vise ?
Boatman53
#9 posted 06-01-2012 11:12 AM
Yes it is a Wilton junior pow-r-arm.
Mauricio
#10 posted 06-01-2012 02:34 PM
Pretty cool clamping idea Jim.
Here’s all I have to share, some cam clamps I made a while back.
Boatman53
#11 posted 06-01-2012 11:20 PM
Mauricio.. Did you make those based on the article in fine woodworking? Are you happy with them? What kind of wood did you use? They are on my list to make with long jaws for planking, and for musical instruments. I dabble with ukulele, dulcimer and banjo, want to have more time for a guitar. Maybe next winter.
Mauricio
#12 posted 06-02-2012 02:05 AM
Jim, I think I did get the idea from FWW. I do use them for light stuff but I didn’t get the geometry right on the cam lever. My best one gets about 50lbs of preassure. If I did it again I’d use steel instead if aluminim and I’d beef everything up a bit. I saw a guy online that claimed he was getting about 200lbs of preassure.
Once I finish my bench I want to make one that will work in a dog whole as a bench hold down.
Oh, I used oak.
Boatman53
#13 posted 06-19-2012 12:10 AM
Well it’s been too quiet on this thread so I thought I’d throw out another gem, but really 500+ views and only 3 people have things to share. I guess all the vise questions are on the different bench threads. Anyway here’s what I made about 10 years ago. Boats require some real creativity when it comes to clamping and this solved a particular problem, namely clamping a toe rail down to the deck for fitting and fastening. The hull prevents any direct clamping. This is shown with a short chain just for the photo. The head goes up at the sheer and the lower part goes down to the keel. It is adjusted to the most convenient link. So if you need to clamp around corners this will do it.
http://i1135.photobucket.com/albums/m628/boatman53/b46c3969.jpg
http://i1135.photobucket.com/albums/m628/boatman53/6c491196.jpg
Mauricio
#14 posted 06-19-2012 01:45 PM
Wow, thats a creative clamping tool. Seeing your work and your inventions is giving me a lot of respect for Boatbuilders.
