How to store finish
Forum topic by Eric posted 05-30-2012 01:49 AM 1756 views 0 times favorited 21 replies Add to Favorites Watch
View Eric's profile
Eric
221 posts in 2479 days
05-30-2012 01:49 AM
Topic tags/keywords: spar finish dry storage store
Recently I’ve been using Spar finish. On the second use from can #1 I noticed some clumps. I returned the can thinking it was a dud.
The same thing happened with can #2. After using most of the can (leaving a considerable amount of air space in the can), I checked the can after about one week of sit time. Sure enough the remaining finish had a dried membrane on top.
Yes I sealed the can lid with a mallet each time.
Is spar finsih susceptible to this? How do you fight against it?
-- Eric
21 replies so far
117063 posts in 3545 days
#1 posted 05-30-2012 01:58 AM
Usually finishes say to store them in a cool dry place. the other thing I do is buy my material in quart containers even though they cost more than gallons but last longer. There’s also a product that you spray in the can just before closing the can that replaces the air that helps preserve the finish.
View gfadvm's profile
gfadvm
14940 posts in 2658 days
#2 posted 05-30-2012 02:03 AM
I have the same problem with Spar Urethane. I have even poured it into glass jars, filling them to eliminate air space and a few weeks later it has turned to gel/goo. The Bloxygen Jim cited works pretty well but is pricey and I hate paying for something that feels like an empty spray can!
13600 posts in 3308 days
#3 posted 05-30-2012 02:22 AM
try this
http://www.rockler.com/product.cfm?page=1396
more here
http://lumberjocks.com/topics/4001
View Loren's profile
10276 posts in 3615 days
#4 posted 05-30-2012 02:48 AM
exhale into the can and then seal it fast.
View Sarit's profile
Sarit
549 posts in 3107 days
#5 posted 05-30-2012 04:39 AM
I think you can put some plastic wrap directly on the surface of the liquid making sure there are no air bubbles.
View Fuzzy's profile
Fuzzy
298 posts in 3956 days
#6 posted 05-30-2012 02:31 PM
I place the UNLIT tip of a Propane Torch into the container and open the valve for several seconds … Propane is heavier than air, so it will displace it. Much cheaper than commercial blockers, and it seems to work. OTOH … exhaling into the can is even more economical, so if it works … why not ???
I’ve also heard of placing discs of Saran Wrap or waxed paper on the surface, but have you to try it … sounds like it should work … ANYTHING to keep Oxygen from contact with the finish.
BE SURE to never return finish to the container that has been out in the open … it will cause the exact same effect.
-- - dabbling in sarcasm is foolish … if you’re not proficient at it, you end up looking stupid … ... ...
View KarenW's profile
KarenW
131 posts in 2156 days
#7 posted 05-31-2012 10:09 PM
I also exhale a big breath into the can and seal it quick. Never had anything skim over when I do that.
-- Happiness does not come from doing easy work but from the afterglow of satisfaction that comes after the achievement of a difficult task that demanded our best. --Theodore I. Rubin
View Eric's profile
Eric
#8 posted 05-31-2012 10:19 PM
Wow. Thanks everyone. I just bought my next quart of spar today. I think I will try the exhale method first. You can’t beat the price!
-- Eric
View fredf's profile
fredf
495 posts in 3677 days
#9 posted 06-01-2012 02:43 AM
I’ve tried dustoff (canned air for cleaning computers) (which is r134 in most cases). it seems to work ok too, although haven’t and a lot of experience with it.
-- Fred, Springfield, Ma
View thedude50's profile
thedude50
3603 posts in 2445 days
#10 posted 06-02-2012 01:15 AM
I too use my propane torch to preserve the spar varnish sorry I forgot to tell you to do this eric My buts the product jim recommends is inert and not flammable therefore it is the preferred method to preserve the stuff. I hardly ever have a can for more than a few days. I always buy the smaller containers to be sure they stay fresh I have never tried exhaling but if that works I would stick with that it is cheep. you know these guys should tell you to buy beloxigen when they sell you a gallon of spar varnish.
-- Please check out my new stores http://woodratnest.com and http://woodshopstore.com
View Grandpa's profile
Grandpa
3259 posts in 2643 days
#11 posted 06-02-2012 03:19 AM
Anyone ever try mixing vinegar and soda in a pitcher then pouring the gas (not the liquid) into the container and placing the lid on it? I saw where a guy got money for this suggestion but have never tried it myself. Just wondering.
fredf
#12 posted 06-02-2012 10:41 PM
Grandpa—that should work even better than exhaling into the can, pure co2! If co2 works ok a co2 cylinder with regulator would make it really easy too.
View RussellAP's profile
RussellAP
3103 posts in 2254 days
#13 posted 06-03-2012 12:14 AM
I use Rustolium quart size ultimate spar, and never had this problem. In fact I’ll pour what I don’t use in my sprayer back in the can and still no problem. And yes I use a filter.
View UncleStumpy's profile
UncleStumpy
734 posts in 2280 days
#14 posted 06-03-2012 08:20 AM
Guys, just store the container upside down. The skin will form on the bottom where there is air.
Sometimes opening up the can the next time might be a little tougher but, no skin.
-- "They don't want it perfect - they want it SPECIAL"
View Clint Searl's profile
Clint Searl
1533 posts in 2329 days
#15 posted 06-03-2012 08:38 AM
Oil based finishes can be stored in the freezer to retard polymerization.
