TS Problem
Forum topic by Gary posted 05-29-2012 03:22 AM 1141 views 0 times favorited 7 replies Add to Favorites Watch
View Gary's profile
Gary
9386 posts in 3635 days
05-29-2012 03:22 AM
Made a box and tried using dye like Joe Landon (trifren) Got a long way to go to get to his level. But, when I cut the lid off, I found a problem with the saw. Got some work to do to get that thing fixed. You can see the runout on the corner. Like that on all 4. Sure wish I had a magic wand… Oh well. Guess it just part of the “fun”
7 replies so far
View Dan'um Style's profile
Dan'um Style
14179 posts in 4185 days
#1 posted 05-29-2012 03:31 AM
Looks like your fence lock is messed up. ,,, good luck.
View Gary's profile
Gary
#2 posted 05-29-2012 03:34 AM
Don’t think it’s the fence Dan. I cut this using a sled…didn’t use the fence. I ordered a digital gage to check but, I think it’s going to be an adjustment at the trunion
View mtenterprises's profile
mtenterprises
933 posts in 2895 days
#3 posted 05-29-2012 01:37 PM
My first guess is if both ends are shallow like this corner shown the box tipped or something moved between cutting the sides as opssosed to cutting the ends or sawdust between your stop and the work piece. If the cut is tappered, corner low step high then corner low step high something is missaligned. And all this depends upon how you cut it , like side side then end end or one continous cut all the way around. After enlarging the photo and making adjustments to it, it looks like you made a continous cut. When doing this type of cut tape and shims are often necessary to keep things from moving.
My question is why did you finish the box before cutting it?
-- See pictures on Flickr - http://www.flickr.com/photos/44216106@N07/ And visit my Facebook page - facebook.com/MTEnterprises
View ajosephg's profile
ajosephg
1880 posts in 3763 days
#4 posted 05-29-2012 03:02 PM
Attach sandpaper to your bench with double sided tape and sand the cut surfaces until they are co-planer
-- Joe
View Gary's profile
Gary
#5 posted 05-29-2012 09:48 PM
Joe, that’s what I did. It’s ok now
mtenterprises: I was really interested in doing the finish, or the dying process, more than the box. I decided to cut the lid off and give it to my wife for …whatever she wants. It’s rub on poly…easy to fix.
View DrDirt's profile
DrDirt
4511 posts in 3945 days
#6 posted 05-29-2012 09:57 PM
Even with the sled – I would do the 5 cut test – and see that your sled is truly cutting at 90 degrees.
Runout wouldnt really show in only one cut direction, it would be rough/burning if it were run-out/blade wobble.
I think there is a angle that is out that is giving you a shoulder at each corner.
Take a caliper and measure the box height at each corner, and I think you will see there is a taper in the cutting.
5-cut demo, from woodwhisperer
http://www.thewoodshop.20m.com/five_cut_method_swf.htm
View Gary's profile
Gary
#7 posted 05-29-2012 11:20 PM
Thanks DrDirt. Gonna give that a try
