Cross-Grain Trim
Forum topic by Alan S posted 05-29-2012 02:52 AM 848 views 0 times favorited 3 replies Add to Favorites Watch
View Alan S's profile
Alan S
180 posts in 3193 days
05-29-2012 02:52 AM
So I’ve designed my own solid wood end table cabinet. The sides are solid wood panels with grain oriented vertically. I am wrapping the bottom with a custom trim and its grain is oriented horizontally. The panels and the trim are about 3/4” thick. The trim is 3” tall. It has just occurred to be that it may be a bad idea to glue these two pieces together. Is that true? Would I be better off screwing the trim on from the inside through elongated holes? Am I overthinking this?
Alan
3 replies so far
View Lee Barker's profile
Lee Barker
2170 posts in 2727 days
#1 posted 05-29-2012 03:02 AM
Mitered joints in front? That’s where you’d want the glue—then screws from that first 5 inches on back.
If your front is likewise vertical grain, you’ve got some other possibilities to think about. One is to build a toe kick type base just inside the sides. It could be as low as 3 inches. Would that work for you?
Kindly,
Alan S
#2 posted 05-29-2012 03:14 AM
Front and back are horizontal grain, so I’m planning on completely gluing those trim pieces in place. And yes, there are miter joints at all the corners.
Alan
Lee Barker
#3 posted 05-29-2012 04:10 AM
Ready, set go!
Kindly,
