Need Advice On Best Way To Level A 18 inch Bandsaw
Forum topic by buildit posted 05-29-2012 02:48 AM 1463 views 0 times favorited 7 replies Add to Favorites Watch
View buildit's profile
buildit
4 posts in 2098 days
05-29-2012 02:48 AM
Topic tags/keywords: bandsaw level secure jet
I am in the process of reconditioning a 18 inch Jet Bandsaw. (weight approx. 325 pounds) I am putting together a workshop the a limited space of one bay of a two car garage. Since my space is limited, my location choice for the saw is limited and the only open floor space is very uneven. I am looking for suggestions on the best way to level the saw while keeping the base steady and sturdy.
I was thinking that a 3/4 inch plywood sheet with shims for level would create a good broad base for the saw to sit upon. I am not sure if I will need to (or should) secure the saw to the floor or to the plywoood.
Any advice or insight is appreciated.
All the best,
Todd
(buildit)
7 replies so far
View mveach's profile
mveach
56 posts in 2292 days
#1 posted 05-29-2012 05:19 AM
We had a large band saw many years ago. I just used some hard wood shims. It doesn’t have to be completely level, just solid.
View ShipWreck's profile
ShipWreck
557 posts in 3662 days
#2 posted 05-29-2012 10:35 AM
buildit: A single sheet of ply might just take on the form of the surface it sits on after a while and end up rocking anyways. I dont have a pic any more of my old base, but I used some yellow pine 2X4’s. I ripped the side/end pieces to 3” and jointed the tops pieces to glue edge, then put a couple nice coats of clear poly. I made it to be 4” wider and longer than the base. I used lag bolts/washers/shims to secure the saw to the base. I’m a pretty tall guy and the 3” height adjustment did wonders for my back. I always thought most BS tables were set too low….... even average height people.
View hairy's profile
hairy
2608 posts in 3441 days
#3 posted 05-29-2012 12:12 PM
I used bolts to level this.
You could build a base, with or without wheels, and attach angle iron to the base.
-- My reality check bounced...
View bondogaposis's profile
bondogaposis
4611 posts in 2260 days
#4 posted 05-29-2012 01:24 PM
I have a sloping garage floor so I had to make levelers for my BS also. I made a base from 2, 1/2” pieces of OSB laminated together to make a 1” thick base then I added a 1/2” T-nut at each corner. Bolted the base to the band saw and screwed in some carriage bolts. Then I took 4 hockey pucks and drilled some shallow recesses to accept the the heads of the carriage bolts. Don’t make the recesses too deep or you won’t be able to use a wrench on the carriage bolt. Placed a hockey puck under each corner and leveled up the band saw using the carriage bolts. You can use a wrench on the square portion of the carriage bolt to turn it with the weight of the saw on it. Here is a picture that makes it more clear, hopefully.
-- Bondo Gaposis
View Doss's profile
Doss
779 posts in 2173 days
#5 posted 05-29-2012 04:45 PM
I was going to recommend something like Hairy showed.
You could also put some washers in that design, but that’s just a thought.
If your’s doesn’t have some flange or base brackets built into the stand, just get 2 3/4” pieces of plywood stacked or some 2×12’s run side to side (like Bondo’s) and then use the same bolt+nut+washer design as Hairy’s.
-- "Well, at least we can still use it as firewood... maybe." - Doss
buildit
#6 posted 06-04-2012 05:57 PM
Thanks for all the suggestions. I think I will start low tech with
Shims then progress to the hockey pucks.
View DS's profile
DS
2853 posts in 2329 days
#7 posted 06-04-2012 06:12 PM
If I recall, the Jet 18” has a platform base.
If it doesn’t already have holes in the corners, you could drill them for leveller studs fairly easily.
