Best tool to remove carpet tack strip and not create divots?
Forum topic by Gary posted 386 days ago 5207 views 0 times favorited 10 replies Add to Favorites Watch
View Gary's profile
Gary
831 posts in 2521 days
386 days ago
I’m taking out carpet in order to use the terrazzo underneath.
I was told the carpet tack strips shouldn’t be pulled up. Instead, I was told the nails should be cut flush to the floor.
What’s the best tool for this?
I have a Porter-Cable oscillating multi-tool; is that the right tool or is there something else folks use?
Thanks.
-- Gary, Florida. http://www.penturners.org/forum/f70/servicepens-2013-a-98908/
10 replies so far
View Bobmedic's profile
Bobmedic
270 posts in 998 days
#1 posted 386 days ago
You could but I don’t see why you can’t pull them up. If there are divots left where the nails were they will be filled with the mortar under the tile.
-- Save lives, ease suffering, reduce morbidity and mortality, stomp out pestilence and disease, postpone the inevitable, and fake compassion. The Paramedics Creed
View Loren's profile
5027 posts in 1844 days
#2 posted 386 days ago
Concrete nails?
You might split the tack strips up with a chisel til you
just have the nails left. A dremel with a cut off wheel
will cut the nails and is pretty maneuverable. An angle
grinder with a cutoff (radiac) wheel will work too.
View MrUnix's profile
MrUnix
270 posts in 396 days
#3 posted 386 days ago
I’ve always just yanked the strips and filled in the divots. If done right, you will barely notice they were ever there. I’m not sure if it is justified, but I would worry that cutting the nails flush would lead to having them eventually start to rust. If you pull the strips up carefully, the divots will not be that big.
-- Brad in FL - To be old and wise, you must first be young and stupid
View Gary's profile
Gary
#4 posted 386 days ago
The professional contractor/terrazzo refinisher said they cut the nails rather than creating divots because:
1. repairing divots is expensive
2. fixing the divots so they’re not glaring, ugly looking mistakes takes experience, hence it’s best done by a professional
3. #2 above is real expensive
Bob, the divots won’t be under anything because we’re refinishing the terrazzo and it’ll become the finished floor.
If someone reads this and has actual experience doing it, please let me know how you do it.
Thanks.
View chrisstef's profile
chrisstef
5566 posts in 1203 days
#5 posted 386 days ago
Id lay down a thin strip of plywood underneath the flattest prybar i could find. How did they fasten the strips to the terrazzo what kind of nails? Masonry i assume?I think a grinder is out. A multi tool like dremel or multimaster will work but take forever. What about splitting the strips, leave the nails, and using a metal cutting blade on a toe kick saw.
-- "there aren’t many hand tools as awe-inspiring as the #8 jointer. I mean, it just reeks of cast iron heft and hubris" - Smitty
View RussellAP's profile
RussellAP
2428 posts in 483 days
#6 posted 386 days ago
Split the wood, use a dremmel multimax 40 with a hacksaw blade. Make some coffee first.
-- Failure does not stop me, it makes me try harder..... because I'm crazy.
34396 posts in 2597 days
#7 posted 386 days ago
I would use a muffler tool that is used to cut bolts when taking off mufflers. It’s an air tool. I would cut the heads of the nails on the strip and then pry up the strips.
Then cut the nails off flush to the surface.
An electric grinder might also work but a little slower.
View Gary's profile
Gary
3694 posts in 1630 days
#8 posted 386 days ago
Just did it in one of the bedrooms. I used one of those “Multi” tools. Mine is a dremel. Slides under the strip and cuts the nail. HOWEVER….it leaves scratches on the concrete. Probably would follow Karson’s advice if it ’s terrazzo
chrisstef
#9 posted 385 days ago
If theyre just scratches the terazzo should buff out. In my experience terrazzo is pretty tough on diamond blades but a grinder will do some damage even with a metal cut off blade.
View BruceCM's profile
BruceCM
11 posts in 441 days
#10 posted 384 days ago
I take it these are concrete nails? If so, they are very hard and would probably be very difficult to cut off.
Yes, pulling them with any kind of bar or hammer claw would likely make a nice big crater
I think what I’d try is to split the wood of the tack strip with an old chisel, then gently tap the protruding nail back and forth (easy does it), then as previously suggested, grab with vice grips and pull straight up. If done right, it should come out and leave a small hole that you sshould be able to patch with some fine sand mortar, like a grout or thinset.
BruceM
-- cut once, measure once and......dam I'm good!
