Bad Habits to good. learning new habits. What are yours?
« back to Coffee Lounge forum
Forum topic by Sac posted 515 days ago 248 views 0 times favorited 10 replies Add to Favorites Watch
View Sac's profile
Sac
236 posts in 533 days
515 days ago
Since getting the tools and machines togather I find myself starting to develope a bad habit. I bought a remote system for my shop fox dust collector. It comes with two remotes. I have one stationed at the table saw. From the table saw I have several dust ports there. They are for the router, disk/belt sander, planer, and the portable craftsman table saw (my dado saw) and of course the steel city table saw. only 3 hoses here. 1-4” for the table saw and 2- 2” for the other tools. Thn dust ports for the bandsaw,scroll saw, sliding miter saw and the drill press are in the back area of the garage.
I find myself not using the dust collector when I go to cut or whatever with wood. I know it must be a learning to make this a habit. Anyway this is one thing I am having to train myself to do. I worked with the airlines for 8 years and in I.T. for 7 years. So I use to wear hearing protection daily. Having to retrain myself in this and learning to train myself in wearing a dust mask also. I have stationed dusk mask at my main bench, table saw and bandsaw. I have hearing protection there also. I set them all in place yesterday so that I may be reminded to use these items when ever working with these machines.
The one habit I am proud to say I picked back up on after many years of not working with wood are push sticks. I have cut out several and always use them. I do not like the idea of my hands near any blades other than a scroll saw blade and even then I keep a keen eye out for safety.
One thing about the airlines. I was a Training coordinator for several years and a safety coordinator as well. So safety I try to make my number one priority every time I step foot into the garage. I replaced the fire extingisher last week and I am getting 1 more for the front of the garage just as a precaution.
So I have some new learning curves here for sure. What might be yours? You know the ones you either quit using or have picked up all good and bad?
Thanks
-- Jerry, Set in the foothills of the Smokey's
View CharlieM1958's profile (online now)
7678 posts in 1117 days
515 days ago
On the good side, I’m very meticulous about blade safety. I always use blade guards when possible, and push sticks when appropriate. I’m also very conscious of kickbacks, and take all precautions to avoid them (including standing out of the path of one if it were to occur).
On the down side, I don’t have a dust collection system, don’t wear a mask or respirator very often, and don’t use hearing protection.
View Bigbuck's profile
Bigbuck
1366 posts in 562 days
515 days ago
I am very cautious when using the table saw, router and other high speed cuting instruments.
But like Charlie I don’t have dust colection and I rarely wear a mask. I have gotten better about wearing hearing protection and try to remeber my safety glasses. However it is not uncommon for me to start cutting on the table saw before I realize I forgot to put my glasses on. Of all my habits I really need to fix this one.
-- Glenn, New Mexico
View sIKE's profile
sIKE
1094 posts in 653 days
515 days ago
I have worked hard on the Saftey Glasses and have just about got that one down. The other biggy for me is not to rush things, I either mess up the cut (try 10 drawer bottoms cut to small) or get hurt when I try to get that one last thing for the day done.
View lew's profile
lew
4508 posts in 654 days
515 days ago
Push sticks and blade/bit safety seem to always be on my mind. Dust, well my dust collector is a squirrel cage furnace blower motor mounted in the basement window- when I remember to turn it on. I do wear a respirator when sanding on the lathe. Hearing, what??!!?? :>) lost a lot of that working around military jets and the rest from old age but I do wear ear protection when running the table saw and router. I do need to get a fire extinguisher, however.
Lew
View brunob's profile
brunob
1476 posts in 1068 days
515 days ago
There are push sticks and then there are push sticks. Most of the commercial ones are an accident wasiting to happen. Make sure that your push stick not only pushes but can hold down the length of the wood (not just the back edge) as well.
-- Bruce from Central New York
View Sac's profile
Sac
515 days ago
Ahh sIke, yea the wanting to get it done factor. Been there. I have been working on that hard when working on the jigs and I have improved that alot. Lew I understand. I did loose alot of mine working with the airlines. Even though they tested ours every year, I felt like it was for the corporate protection since know one was every advised to do anything about thier hearing. Kickbacks as most of you have mentioned can get super ugly fast. Point made brunob. I do need to modify or make some new push sticks.
You know. I have only turned my lathe on once to make sure it worked. I need to bolt it down and set down some safety rules on the wall behind it since this is my first one. I use to work with metal lathes and mills many many moons ago. Safety Glasses were always a priority there. Even though I have some I have yet to wear them mistakingly thinking my glasses were good enough.
View Wayne's profile
Wayne
21 posts in 873 days
515 days ago
Can anyone point me to the do’s and don’t’s of good push sticks? I must confess I have never used them and it is only a matter of time before I will be missing fingers.
View sIKE's profile
sIKE
515 days ago
I just bought this one couple of weekends ago, and though I haven’t heavily used it I really liked it.
View EdC's profile
EdC
458 posts in 740 days
509 days ago
Safety has never been a problem for me,after spending most of my life working as a Paramedic. I have had the opportunity of seeing the results of what a mistake will do to the human body. And I have have been blessed with attending one of the best Woodworking schools in the country. At school safety came before anything else.
I have found for me that if I just leave my safety glasses I don’t have to remember to put them on. My hearing protection, I keep around my neck, as well as my dust mask.
But I am still like everyone else and have to remind myself to slow down and think, this has been my weakest link.
-- Ed - Milan, IN
View SteveKorz's profile
SteveKorz
2030 posts in 613 days
509 days ago
About 5 years ago, I was chasing methamphetamine addicts into a field and I got into some Annhydrous Ammonia and it burned the top part of my lungs up. For years I wore a respirator when I did anything in the shop, construction, burned leaves, etc. Now, I’ve gotten out of that habit. I need to start wearing it again (it’s hard to do that when it’s 90 degrees in your shop). I don’t use a dust collecter.
I do wear hearing protection, but only eye protection if I have my glasses on (which is terrible!). I’m an avid believer in push sticks. I make my own out of any softwood, just because I know what feels right in my hand. Store bought ones are expensive, and sometimes they don’t “feel right” in my hand. Plus, if it gets chewed up in the saw, so what? Make another.
I got cut by a tablesaw about 4 years ago (I’ve still got all 10!), and since then I’ve woke up to the fact that my safety methods with them were terrible. I’m much more cautious now than I was, and I take that approach to all my machines.
I also have tried to NOT work when I’m tired. It doesn’t matter what I want to get done, if I’m going to work with machinery or sharp knives, and I’m tired, I quit. Period.
Some of us, without a mentor, are subject to learning on our own. I wish this site was around 15 years ago when I started!!! The information from all these great, experienced people is invaluable!!
