Bandsaw Speed
Forum topic by BruceCM posted 05-26-2012 03:51 PM 4711 views 0 times favorited 7 replies Add to Favorites Watch
View BruceCM's profile
BruceCM
11 posts in 2243 days
05-26-2012 03:51 PM
Just put together my Harbor Freight 14” Bandsaw. It has 4 blade speeds: 600, 1140, 1670 and 2670 FPM. The instruction book doesn’t seem to say what these speeds should be used for. Might someone have an idea of examples of what to cut at each speed? And which would be the best general use speed?
Thanks for any assistance
BruceM
-- cut once, measure once and......dam I'm good!
7 replies so far
View Bill White's profile
Bill White
4930 posts in 3959 days
#1 posted 05-26-2012 05:13 PM
http://vintagemachinery.org/math/sfpm.aspx
Check this site. Good info.
Bill
-- bill@magraphics.us
View MrUnix's profile
MrUnix
6714 posts in 2197 days
#2 posted 05-26-2012 05:26 PM
Required speed depends on what you are cutting and what blade you have on the machine. Typically, you will use the fastest speed for wood, and slower speeds for plastics and possibly soft metals like aluminum. The manufacturer of your blade should have a chart showing what speed to use for various materials.
View AHuxley's profile
AHuxley
653 posts in 3320 days
#3 posted 05-26-2012 06:48 PM
If you are cutting wood just use the fastest speed. Small wheeled bandsaw still run a little slow for many wood cuts but it is a compromise that has to be made.
View longgone's profile
longgone
5688 posts in 3307 days
#4 posted 05-26-2012 06:52 PM
The 2670 fpm is usually best for woods..just like a table saw or miter saw cuts best at a higher rpm. The slower speeds are best for metal, meat, plastics, etc.
View SCOTSMAN's profile
SCOTSMAN
5849 posts in 3584 days
#5 posted 05-26-2012 07:39 PM
To tell the truth most people I know including myself never or very seldom change speeds for woodcutting It is imperitive for metal to cut slowly of course but for wood set it to a speed you like then get cracking. have fun Alistair
BruceCM
#6 posted 05-27-2012 04:22 PM
Thanks for the feedback and link. Sounds like I need to keep in on the highest speed for all woodworking? But might one slow it down for either hardwoods or very thick cutting…or would speed matter based on hardness or thickness of cut?
And the speed link looks very interesting…but this model of HF 14” bandsaw (#67595) has 3 shaft pulleys…the motor, the intermediate (both with 4 different pulley sizes) and the end drive that connects to the lower wheel….so not sure how to convert this into two pulley equivalent.
BruceM
Bill White
#7 posted 05-27-2012 04:46 PM
Measure each pulley’s OD. then ya can figger the sfpm for each pulley set.
SFPM=surface feet per minute.
Bill
