Foot Pedal's
Forum topic by Sac posted 102 days ago 94 views 0 times favorited 4 replies Add to Favorites
View Sac's profile
Sac
192 posts in 119 days
102 days ago
Hello folks, Yep it’s me again. I’ve read a few articles on foot pedals here at LJ’s. Is there any one that may be safer than another? This one I found at the Rockler site. Are there others you might suggest over this one. I haven’t really found any at a lower price yet because I would like to have 3. Router/Tablesaw and ROS. Your thoughts and opinions please.
Thanks
-- Jerry, Measure 10 times cut once. Set in the foothills of the Smokey's
View John Gray's profile
John Gray
697 posts in 371 days
102 days ago
Got one for my scroll saw and like it. Bought at a wood working show for $20.
View WoodJack49's profile
WoodJack49
189 posts in 249 days
102 days ago
I bought this one a couple of years ago. It was never as convenient as I thought it would be. I went ahead and used it a few dozen times and then it just quit working. Tossed it in trash and went back to working the old way.
-- Jack - Mission Viejo, Calif
View Loren's profile
180 posts in 134 days
102 days ago
I used one all the time for turning on routers, vacuums, and
also as a switch for my vacuum pump,which doesn’t have
a switch.
With the vacuum pump I built some clamping fixtures and I
use the foot pedal to switch the pump off, reposition the work,
then switch it on again.
-- http://amherstcabinets.com - also a marketing consultant with expertise in direct response marketing for woodworking and online business building
View DaveH's profile
DaveH
241 posts in 264 days
102 days ago
I believe OSHA does not allow foot operated equipment in manufacturing anymore unless there are safe guards in place to protect the hands, arms, legs, etc when operating the tool. I would never use one on a router table. Too easy to step on the switch accidentally and route your hand. I worked in a machine shop years ago machining valve bodies. After clamping a part in place, you hit a foot peddle and 5 or 6 taping heads actuated at once to cut threads in the valve. Milled hundreds of these parts in a day. Really boring. Anyway, a couple of times I dozed off after clamping the part and did not pull my hands back out of the way after clamping. I was lucky enough to wake up before I cut threads in my hands.
I’d never put a foot pedal on a power tool.
http://www.osha.gov/SLTC/etools/machineguarding/presses/footcontrol.html
-- Dave Herron, Boise, ID -- “That which does not crash the browser, makes it stronger”
Bookmark And Share This Page
