Dust Collection - An Important Element
Forum topic by NedG posted 05-26-2012 02:37 PM 1345 views 0 times favorited 9 replies Add to Favorites Watch
View NedG's profile
NedG
56 posts in 2183 days
05-26-2012 02:37 PM
I recently treated myself to a new Delta Unisaw and included a dust collection system [Harbor Freight collector, Wynn canister filter35A274nano, and a Thien Top Hat separator by Ghostes (see YouTube)]. This is, in my opinion, an excellent, modest priced, set-up.
However, if keeping dust off the shop floor and away form your lungs is the objective, the most important part of this system is a zero clearance throat plate on on the saw. This simple shop made device keeps the dust in the cabinet and away from you and your shop. So do consider adding this to your system and use it when possible. —- Ned
9 replies so far
View Bill White's profile
Bill White
4816 posts in 3830 days
#1 posted 05-26-2012 03:11 PM
ZCIs won’t stop dust from the top of the blade dang it. Don’t cut off all air flow to the cabinet either.
Bill
-- bill@magraphics.us
View NedG's profile
NedG
#2 posted 05-26-2012 06:03 PM
Bill: I hate to disagree with you, but a zero clearance throat plate does a great job of keeping most – not all , but most – dust off the top of the saw, nor does it reduce significantly the air flow to the collector. Most saws, the Unisaw included, has an abundance of gaps, specifically at the top of the cabinet where it abuts the top. -—- Ned
View dpop24's profile
dpop24
115 posts in 2439 days
#3 posted 05-26-2012 09:23 PM
I haven’t even made my ZCI yet for my saw so have no practical experience so this is an innocent question. If the cutting action (saw blade teeth through wood) occurs on the top of the saw, how does a ZCI keep dust off the top of the saw? Seems like it would keep the dust on top and keep it from getting into the cabinet.
-- If it ain't broke, take it apart and find out why
dpop24
#4 posted 05-26-2012 09:24 PM
Double post
View Vrtigo1's profile
Vrtigo1
434 posts in 2861 days
#5 posted 05-26-2012 09:38 PM
Without weighing in one way or the other, it does kind of make sense. Since the blade doesn’t begin cutting until it contacts the workpiece on the downstroke, it seems reasonable to think it would carry the sawdust down with it, through the insert and into the cabinet.
View gfadvm's profile
gfadvm
14940 posts in 2559 days
#6 posted 05-27-2012 02:02 AM
I get a LOT more dust on the top of my saw when using my ZCI with the saw hooked up to my dust collector. Just sayin my experience.
View pmayer's profile
pmayer
1012 posts in 2934 days
#7 posted 05-27-2012 02:17 AM
I agree with the posters who have suggested that this is not a best practice. With a zero clearance blade not enough dust gets into the cabinet as the air flow is severely constrained with a ZCI. I aways use one for thin rips but other than that I use a standard insert and I get much better dust collection when I do.
View Sawkerf's profile
Sawkerf
1730 posts in 2938 days
#8 posted 05-27-2012 03:27 AM
I find that I have less dust on the table if I use the stock insert. The reason, I believe, is that there’s slightly better air flow at the blade below the workpiece.
When you’re ripping a board, the only flow path for the air is through the kerf behind the blade. If you’re using a ZCI, it’s opening is ~1/8”. If you’re using a stock insert, that opening is nearer 1/2”. With less restriction, the airflow increases.
View redryder's profile
redryder
2393 posts in 2971 days
#9 posted 05-27-2012 04:08 AM
gfadvm: ditto, ditto, ditto…. if you think dust and sawdust doesn’t come back at you when using a zci then you haven’t cut much wood…..................
-- mike...............
