| Forum topic by rockindavan | posted 358 days ago | 860 views | 0 times favorited | 7 replies | ![]() |
358 days ago |
I got some 6/4 curly maple a couple of months ago and have been waiting until I needed it for a cabinet top. I cut it into 4’ sections, and everyone of them is twisted 1/4”. I ended up having to take almost 3/8” to get it true enough to glue up. I’m a little concerned now that its going to twist up now that it is glued up. The top is 23” wide so there is plenty room for it to get out of whack. Anyone else have same problems with soft maple and is it common to warp so bad? |
7 replies so far
#1 posted 358 days ago |
Are you sre the lumber was dry? It sounds as though it wasn’t. The moisture content of a board should be checked, prior to use. Between 6-8% is what you’re looking for. Lee -- by Lee A. Jesberger http://www.prowoodworkingtips.com http://www.ezee-feed.com |
#2 posted 358 days ago |
Its been in the shop for 2 months..AC has been on for the last 3-4 weeks and everything has been stable otherwise. |
#3 posted 358 days ago |
Sometimes there are stresses in the tree because of the orientation of the wood cells. There is not much you can do about it except turn the log on the sawmill 180 degrees after every board or two. It sound like that you have relieved the stress. I would keep in tight in the clamps until just before the moment that you need to attach it to the cabinet. Once it gets attached to the cabinet, it will likely be OK. Don’t take it out of the clamps and let it sit for weeks. When I started woodworking, I always wanted to make the top first in a project because it was the prettiest part of the whole deal. You pick out the best wood and do that first. Well, I found that that is backwards. Now, I make the top last and attach it quickly after it comes out of the clamps and is sanded. -- Wood-Mizer LT15 |
#4 posted 358 days ago |
I have a small amount of curly soft maple on hand I bought some years ago. s I’ve made projects with it I’ve not had any warping/twisting problems, at least no more than any other wood. Like WDHLT said, sometimes there are stresses in the tree you can’t do much with. But I don’t think what happened to you is common, just one of those things. -- I long for the days when Coke was a cola, and a joint was a bad place to be (Merle Haggard) |
#5 posted 358 days ago |
I would not recommend using the AC in the shop. The moisture content of the exterior surfaces of the wood will be much different than the center of the boards. -- Oldworld, Fair Oaks, Ca |
#6 posted 358 days ago |
If the boards warped almost as soon as they were cut, it is stress in the wood. If the wood was not dried properly, it can have quite a bit of stress in it. Also, internal stresses caused by limbs can be a factor. If you cut the 4 ft lengths and they were warped the next day, it is most likely because of moisture content. The moisture content of the board in the middle can be different than on the outer edges. When you expose new wood to the air the moisture content will seek to acclimate to your shop and can cause warping again. When I cut any long pieces, I always sticker, stack and weight down the shorter pieces for a day or two in order for them to settle down. I learned this the hard way when I first started ww. I had milled and cut several boards for a project and when I returned the next day they were warped all over the place. |
#7 posted 358 days ago |
What wdhl said is spot on. All I use is figured wood. That is the nature of figure. Some stays nice and flat and some don’t. Get your top made and attached. Make sure you allow for expansion and contraction in attaching your top. Its beautiful stuff. bob -- Bob www.bobkloes.com |
| Forum | Topics |
Woodworking Skill Share
8784 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1522 |
3542 |
15755 |
Hand Tools
2029 |
Jigs & Fixtures
494 |
Wood & Lumber
2833 |
808 |
Focus on the Workspace
900 |
766 |
Woodworking Trade & Swap
2737 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6148 |
