Fancy flutes on Mahogany Fruit Bowl
Forum topic by Col Baker posted 362 days ago 747 views 0 times favorited 8 replies Add to Favorites Watch
View Col Baker's profile
Col Baker
16 posts in 366 days
362 days ago
Hi – I have a question for members on the attached Mahogany bowl which I saw on a TV program. It is a turned Mahogany Fruit Bowl with some nice fluted surface under the bowl. How on earth can this be machined or manufactured like this? There must be a trick to it. I would appreciate any input from Lumberjocks members. It has me stumped.
-- Col B.
8 replies so far
View Mark Shymanski's profile
Mark Shymanski
3966 posts in 1883 days
#1 posted 360 days ago
I don’t see an attached bowl?
-- "Checking for square? what madness is this! The cabinet is square because I will it to be so!" Jeremy Greiner LJ Topic#20953 2011 Feb 2
Col Baker
#2 posted 360 days ago
Hi Mark – Didn’t attach did it ? I’ll try here again. Thanks for reply.! https://s3.amazonaws.com/ljimg/m4pedyu.jpg!
Hmm – won’t actually insert a picture here Doing something wrong
Sorry.
-- Col B.
View rejo55's profile
rejo55
148 posts in 412 days
#3 posted 360 days ago
Hmmm. Beddy, beddy interrresting. I wonder if it is “mahogany” wood or a “mahogany colored” casting. What do y’all think?
Have a good’un
Joe
-- rejo55, East Texas If there were no trees, there wouldn't be much wood.
View tyskkvinna's profile
tyskkvinna
1294 posts in 1156 days
#4 posted 360 days ago
My CNC mill could easily make this. It would be easiest with the rotary attachment, but doable without. I’m sure you could do it “by hand” on a lathe if you were able to somehow index the turning carefully and then use a router attached to it, like you sometimes see the attachment for fluting? But instead of a straight line, it would require a lot of up and down.
-- Lis - Michigan - http://www.missmooseart.com - https://www.etsy.com/people/lisbokt
View horologist's profile
horologist
75 posts in 1909 days
#5 posted 360 days ago
A rose engine would do it but probably a lot cheaper to buy the CNC mill.
-- Troy in Melrose, Florida
View Barbara Gill's profile
Barbara Gill
153 posts in 830 days
#6 posted 360 days ago
The flutes can also be carved by hand or rotary tool but in this case I agree about the Rose Engine.
-- Barbara
View adaughhetee's profile
adaughhetee
80 posts in 853 days
#7 posted 360 days ago
You could do it on a router lathe like Alex’s.http://lumberjocks.com/projects/55767 use it to turn the outside then index it and make the flutes with a core box bit. I have the book Router Magic and they turn flamed finals in that way with a pattern.
View Hogger270's profile
Hogger270
11 posts in 430 days
#8 posted 129 days ago
Check out “The Principles & Practice of Ornamental or Complex Turning” by John Jacob Holtzapffel from a libbrary or buy your own copy. Both hard bound and soft cover reprints are available.
