making mitre box?
« back to Hand Tools forum
Forum topic by 12strings posted 05-25-2012 04:48 PM 1871 views 0 times favorited 3 replies Add to Favorites Watch
View 12strings's profile
12strings
434 posts in 2622 days
05-25-2012 04:48 PM
I’d like to make a mitre box for hand-cutting 90 and 45 degree pieces. I’m not sure how to make the initial cuts in the box to make sure they are accurate. I’m assuming I should use the same saw that will be used with the box, right?
thanks
-- I'm strictly hand-tool only...unless the power tool is faster and easier!
3 replies so far
View Nicky's profile
Nicky
695 posts in 4330 days
#1 posted 05-26-2012 02:42 PM
Layout your 90 and 45 deg slots with a good combo square. Extend the lines down the sides of the mitre box, inside and outside. Carefully cut the lines (trying to split your layout lines ) with the same handsaw that will be used regularly with the box.
Check out http://video.renovateyourworld.com/v/21291653/how-to-build-a-miter-box.htm
I have a few different sizes that I use. Mainly for smaller moldings. I use a small Gents saw on mine, that I only use for my mitre boxes.
-- Nicky
12strings
#2 posted 05-27-2012 08:41 PM
Thanks, I guess I just don’t trust myself to saw that straight.
View Infernal2's profile
Infernal2
107 posts in 2435 days
#3 posted 05-27-2012 09:01 PM
12,
You could always (after marking out your lines) hang a speed square off the back of your cut to help ensure a straight kerf. I prefer a speed square in these types of situations simply because the base is usually a little less “in-the-way” than a standard right-angle.
