Do you have a traditional hardwood workbench?
Forum topic by parkerdude posted 05-25-2012 04:03 PM 2020 views 0 times favorited 19 replies Add to Favorites Watch
View parkerdude's profile
parkerdude
182 posts in 3571 days
05-25-2012 04:03 PM
Topic tags/keywords: workshop question finishing glue-up
I’m curious, do any of you use your hardwood traditional woodworking bench for glue ups and finishing, without protecting the surface?
I’ve seen a woodworking show that does this fairly often. How would you keep the bench-top clean and true?
I don’t understand it.
Comments?
-- dust control
19 replies so far
View rockindavan's profile
rockindavan
299 posts in 2755 days
#1 posted 05-25-2012 05:02 PM
I only will if I am certain there won’t be squeeze out. Otherwise just use an assembly table with a melamine top.
View SPalm's profile
SPalm
5321 posts in 4001 days
#2 posted 05-25-2012 06:01 PM
My bench is Douglas fir, but traditional looking. I do not have an assembly table, so I use it for glue-ups and finishing. Cutting boards can be extremely messy to make. I use either wax paper or a cheap shower curtain liner to protect it. So I am not really answering your question.
But judging by some of the comments I have on my bench, I should have more dings and glue drops to prove that I use it. Ya just can’t win :)
Steve
-- -- I'm no rocket surgeon
View Bill White's profile
Bill White
5052 posts in 4080 days
#3 posted 05-25-2012 06:49 PM
My bowling alley bench get a lot of use for planing and vice use. Other stuff goes to the assy. table.
Bill
-- bill@magraphics.us
View Mike DeCarlo's profile
Mike DeCarlo
40 posts in 2877 days
#4 posted 05-25-2012 07:28 PM
I made my bench from an old picnic table, its got an end vise, a wagon screw vise, and a side vise. It even has drawers between the legs to stow all of the ‘everyday’ tools.
-- http://decarlowoodworks.blogspot.com
View PurpLev's profile
PurpLev
8540 posts in 3768 days
#5 posted 05-25-2012 07:30 PM
I do, but use a sheet of masonite to protect the surface when doing glue ups and finishing.
View TechRedneck's profile
TechRedneck
769 posts in 2976 days
#6 posted 05-25-2012 07:51 PM
I combined a traditional workbench with an assembly table.
http://lumberjocks.com/projects/60275
For the wood bench I keep a coat of BLO on it. The assembly table gets a coat of paste wax every so often. Then let the glue drip where it may. The drips pop right off and get swept up with the shavings.
-- Mike.... West Virginia. "Man is a tool using animal. Without tools he is nothing, with tools he is all.". T Carlyle
View Gregn's profile
Gregn
1642 posts in 3103 days
#7 posted 05-25-2012 11:15 PM
At this time I don’t have a traditional hardwood bench or know that I want one. My current bench has a masonite top on that can be replaced if need. I did this cause my bench serves many purposes in the shop. I have done glue ups without any protection other than wiping up glue with a damp rag, if I should miss a glue drop it generally comes off quite easy with a scraper or chisel.
If I had a traditional hardwood bench that I were going to use as an assembly table I think I would want to keep a piece of masonite to put on top of the bench.
View Gshepherd's profile
Gshepherd
1727 posts in 2321 days
#8 posted 05-25-2012 11:27 PM
I used to, then I came across a couple of the cabinets they use for plan storage, made one of them into a rolling assembly table with a 2 inch hard maple top. I wished I done it sooner, if you want to see it I will post a few pics of it. The top is like 30×40 which is better suited for glue ups and assembly. I keep my other bench for everything else but glue ups.
-- What we do in life will Echo through Eternity........
View ShipWreck's profile
ShipWreck
557 posts in 3872 days
#9 posted 05-25-2012 11:47 PM
My woodworking bench was built on a job site by my helpers during a 1 hour lunch break. They did a pretty sweet job considering that it was from scraps. I have no plans to replace it any time soon.
View Loren's profile
10477 posts in 3767 days
#10 posted 05-25-2012 11:48 PM
Yes.
Glue can be popped off an oiled hardwood bench with a chisel
but if doing a messy glue up or something large I set
up an assembly table.
View Martyroc's profile
Martyroc
2712 posts in 2425 days
#11 posted 05-26-2012 01:55 AM
I cant use a nice hardwood bench, I would be too concerned about screwing it up. Some of the beutiful workbenches I see on here, I would sooner put in my living room or dining room before I did any work on it.
My workbench is Pine and when I destry the top I just replace it, plus since the pine is soft theer is a better change of that taking the beating then the hardwood I am working with.
-- Martin ....always count the number of fingers you have before, and after using the saw.
View Brandon's profile
Brandon
4152 posts in 3071 days
#12 posted 05-26-2012 01:59 AM
For heavy glue ups I have a roll of leftover tar paper that I use to cover the bench. I’m not too concerned about glue spots here or there, but It’d be a lot of clean up work there’s a lot of squeeze-out.
-- "hold fast to that which is good"
View woodworker59's profile
woodworker59
560 posts in 2320 days
#13 posted 05-26-2012 02:00 AM
My shop is small so I don’t have room for a bench and an assembly table so yes I use my bench. My top is made of two sheets of 3/4” OSB sandwiched between two sheets of 1” MDF so its pretty easy to keep clean.. if I do drop glue on it, it wipes right off. I would agree, if I had one of those fancy hardwood benches I may be more concerned and careful..
-- Papa...
View redryder's profile
redryder
2393 posts in 3221 days
#14 posted 05-26-2012 06:00 AM
A lot of the fancy hardwood bench’s you see on this site look more like they belong in the living room. I guess you need to only use hand tools on them. My two work benches look used and abused from glue, paint, stain and things I can remember. I use an orbital sander on them periodically but …...................
-- mike...............
Smitty_Cabinetshop
15519 posts in 2737 days
#15 posted 05-26-2012 06:04 AM
^ What Loren said, not tough to pop it off. (I do glue ups on my bench)
