| Forum topic by Milo | posted 389 days ago | 1994 views | 0 times favorited | 31 replies | ![]() |
389 days ago |
Topic tags/keywords: question I have an opportunity to get some wood from a pearwood tree that I can take to be milled. I don’t hear much about pearwood though. Should I take this chance? Is the wood good for boxes/cabinets/etc.? Thank you for your input, Milo -- Beer, Beer, Thank God for Beer. It's my way of keeping my mind fresh and clear... |
31 replies so far
#1 posted 389 days ago |
I can’t imagine a pear tree being of sufficient size to mill into boards. How thick is it? here are some images of pear wood. https://www.google.com/search?hl=en&biw=1920&bih=967&tbm=isch&sa=1&q=pear+tree+wood&oq=pear+tree+wood&aq=f&aqi=g1g-S4g-mS1&aql=&gs_l=img.3..0j0i24l4j0i5i24.33511.34413.0.34581.5.5.0.0.0.0.82.387.5.5.0...0.0.8a8PWupBlWQ -- Failure does not stop me, it makes me try harder..... because I'm crazy. |
#2 posted 389 days ago |
Can’t say I have experience with pear trees, although I have made some nice small projects from apple and peach trees. I will say that if your going to use fruit trees, use the trunks only. The limbs will twist and bow on you when you try to use them because of the tension in the limbs. -- I don't make mistakes, I have great learning lessons, Greg |
#3 posted 389 days ago |
Russell, To quote the owner “it’s frickn’ huge”. Maybe it’s not pearwood? I’m thinking I may need a little more info here. The backup plan is a birch he is cutting down in a week or two. I plan on DEFINITLY trying to get that one. -- Beer, Beer, Thank God for Beer. It's my way of keeping my mind fresh and clear... |
#4 posted 389 days ago |
Rule 1. Never say no to free wood. Pear it is a fine grained wood, turns beautifully, planes and sands well. -- ... Never Apologise For Being Right ... |
#5 posted 389 days ago |
I know a few turners have taken pearwood and turned them into bowls. Haven’t heard about it being used for other types of projects. -- Mike ---- Visit my woodworking blog: http://sawdustnewbie.com |
#6 posted 389 days ago |
BigYin, I was kinda thinking that myself, especially after he said it was a large log. That, plus the birch, should make a nice little stash of wood. I’ll probably mill it 4/4 and 8/4. You can go pretty much anywhere from there. Now if I can just get them moved… Solar Kiln, here I come!!! ;) Milo -- Beer, Beer, Thank God for Beer. It's my way of keeping my mind fresh and clear... |
#7 posted 389 days ago |
Be sure to seal endgrain well for drying. I seem to remember reading that it is prone to checking. I believe it ranges from pretty mild grain looking like beech all the way to spectacular. -- Woodworking shouldn't cost a fortune: http://lowbudgetwoodworker.blogspot.com/ |
#8 posted 389 days ago |
Here’s something I found: “First published in British Woodworking Magazine July 2008 Pear wood is one of the most sensual and satisfying of hardwoods that a furniture maker can encounter. The structure of the wood is hard, so hard that the sharpest of tools are required to work it. This allows you to cut the finest of details and form the most delicate of shapes. Pear wood is also, unlike almost any other hardwood, without figure. I say without figure meaning without the usual graphics of timber. Pear wood is a timber that hasn’t lines running through it, but instead has a colour shift. The general colour of pear wood is almost dark fleshy colour, pinky brown is a favourite description. That colour can shift orangey or purpley brown on either side of the main colour. On rare occasions you can get dark purple, blacky contrasting heartwood colour but that is rare. Generally the colour of pear wood is a fleshy pink.” There is more information at the original page. -- Best regards, Jack -- I may not be good, but I'm slow -- www.BarnhillWoodworks.com |
#9 posted 389 days ago |
Milo I remembered … Pear wood is used for top end saw handles. look here http://www.wenzloffandsons.com shorty -- ... Never Apologise For Being Right ... |
#10 posted 389 days ago |
I have a similar offer right now. The trunk is probably 8 inches in diameter. I’m not one to turn down wood. I figure I’ll make chisel handles. I know the local turners were interested in it. Pear is really pretty. -- My dad and I built a 65 chev pick up.I killed trannys in that thing for some reason-Hog |
#11 posted 389 days ago |
James Krenov was also known to fairly often use pear wood in his pieces. -- Best regards, Jack -- I may not be good, but I'm slow -- www.BarnhillWoodworks.com |
#12 posted 389 days ago |
Milo, it is very hard for me to turn down free timber. So, I’d say if you can get it and have room for it, there’s no reason not to. I have learned some lessons though. Some free trees aren’t even firewood worthy. Also, I’ve heard owners say that the log is “frick’n huge” before. I show up and the log is 20” in diameter. I don’t even think anything under 30” is big. Then again, I usually slab 40-52” wide logs. Relative I guess. Get it and the birch. -- "Well, at least we can still use it as firewood... maybe." - Doss |
#13 posted 389 days ago |
Milo, Hey, you can get the wood, etc. make a small box out of it for testing… if it turns out GOOD, make some more boxes, etc. -- Have Fun! Joe Lyddon - Alta Loma, CA USA - Home: http://www.WoodworkStuff.net ... My Small Gallery: http://www.ncwoodworker.net/pp/showgallery.php?ppuser=1389&cat=500" |
#14 posted 389 days ago |
Totes and knobs, chisel handles, saw handles, plumb bobs…...the uses go on. -- bill@magraphics.us |
#15 posted 389 days ago |
Bill White... there ya go! YES! -- Have Fun! Joe Lyddon - Alta Loma, CA USA - Home: http://www.WoodworkStuff.net ... My Small Gallery: http://www.ncwoodworker.net/pp/showgallery.php?ppuser=1389&cat=500" |
| Forum | Topics |
Woodworking Skill Share
8846 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
69 |
Joinery
96 |
Finishing
1599 |
3594 |
15981 |
Hand Tools
2098 |
Jigs & Fixtures
501 |
Wood & Lumber
2908 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2777 |
LumberJocks.com Site Feedback
1553 |
Coffee Lounge
6133 |
