Staining Cherry
Forum topic by NedG posted 360 days ago 1121 views 1 time favorited 15 replies Add to Favorites Watch
View NedG's profile
NedG
21 posts in 482 days
360 days ago
I just made some cherry picture frames and stained them with a Min Wax product, the typical yellow-can stuff. The result ended up in the scrap pile, as the cherry became blotched and looks really, really, bad.
What went wrong?
I have often used no stain on cherry, only a clear finish, but that tends to be gray and dull. Time doesn’t work well as it takes, well, a long time.
So, what to do? Is there a not too complicated method of getting a rich finish that doesn’t hid the grain? I’ve researched the old posts and am befuddled.
Thanks very much!
Ned
15 replies so far
View RussellAP's profile
RussellAP
2394 posts in 454 days
#1 posted 360 days ago
This is the only comment you’ll need, https://charlesneilwoodworking.3dcartstores.com/Charles-Neils-Pre-Color-Conditioner--Blotch-Control_p_47.html order a couple jars of this and you’ll never throw away another piece of blotched wood, I promise.
-- Failure does not stop me, it makes me try harder..... because I'm crazy.
View jmos's profile
jmos
637 posts in 537 days
#2 posted 360 days ago
I’m surprised to hear you don’t like the results of clear coating cherry. It usually looks very nice when it’s done, and over time the wood darkens and looks terrific. Personally I never stain cherry; always prefer it natural, but each to their own.
Yes, cherry can blotch. There are some specific products out there to control blotching that you apply before the stain to regulate absorption. You can also use a spit coat of shellac. A 1lb cut will usually do it. Apply and let dry then stain on top of it. You can then use whatever topcoat you like, everything is compatible with shellac.
-- John
View ajosephg's profile
ajosephg
1719 posts in 1729 days
#3 posted 360 days ago
I have never stained cherry either, and have never ever had blotching when using minwax polyu solvent based varnish.
-- Joe
View Jimbo4's profile
Jimbo4
710 posts in 931 days
#4 posted 360 days ago
Why would anyone want to stain cherry?
-- *Arachnoleptic*: The frantic dance performed just after you've accidently walked through a spider web.
View Jerry's profile
Jerry
1429 posts in 1715 days
#5 posted 360 days ago
Cherry is the only wood species I sell in our kitchen jobs when the customer insists they want a stain finish. So typically we do walnut and hickory natural but whenever someone wants stain finish, I go with Cherry. Certainly I have done Cherry with just a natural coat and it turns out very nice, however my experience has been that Cherry stains very nicely without much extra effort.
I do not utilize any pre stain conditioners and still get a nice finish. Cherry simply needs to be sanded properly while utilizing grits in progression. I do not go over 150 grit and have had some good results going to just 120 grit. I do think pre stain conditioners will work well, but proper sanding technique is your best friend whenever it comes to stain finish results.
And to those who wonder why anyone would ever stain Cherry? Whenever I have a paying customer who demands a certain finish I cannot achieve with natural finishes, I quickly run, not walk, to Cherry. I can make Cherry look stunning with many stain grade finishes.
-- Jerry Nettrour, San Antonio, www.topqualitycabinets.net
View Fuzzy's profile
Fuzzy
249 posts in 2156 days
#6 posted 360 days ago
I must admit to being in the “other” camp on this one … I use a fair amount of Cherry, and I always color it … stain/dye/lye … I just find it boring in it’s natural state of color. I personally find it hard to believe how many folks actually prefer to leave it natural. I believe some are simply apprehensive about dealing with it’s propensity to blotch horribly. The nasty salmon-pink shade does eventually turn to something more attractive (what isn’t ?), but, I find I can hasten and improve on the process by judicious use of colorant.
I have found Charles Neil’s Blotch Control to be a mandatory first step in my finish application … it not only guarantees zero blotching … it also negates the need to cull out otherwise beautiful Cherry due to sapwood. I can make the most use out of stock containing sapwood so it basically offsets the price of the product. His product makes sapwood simply disappear, so there is no reason to work around it or try to hide it.
I have, on occasion had blotching occur with just the application of poly … ANYTHING that contains oils or resins can cause blotching to occur, even if you’re not adding color … it’s all in how the irregular grain accepts the finish.
-- - dabbling in sarcasm is foolish … if you’re not proficient at it, you end up looking stupid … ... ...
View NedG's profile
NedG
#7 posted 360 days ago
Thanks to all that responded to my inquiry about blotching cherry stains. As a result, I looked into Charles Neil’s product and ordered some today. I, as most of you, prefer stained cherry rather than natural stain; I just don’t have the time to let nature (sunlight) do it’s work, and I find unstained cherry with a clear finish to be dull and lifeless. Thanks again. —- Ned
View TCCcabinetmaker's profile
TCCcabinetmaker
735 posts in 523 days
#8 posted 360 days ago
Gemini makes an annyline dye and wiping stain that works verry well on cherry, you may see a bit of blotch with the dye, but the wiping stain takes care of it, gives the finish a real “depth” to it. You will have to go to gemini’s site to find a dealer near by that sells it however, cause they are one of those company that licenses only a few stores per area to sell this kind of product, BUT I believe they also manufacture it for sherwin williams as well, but you’ll likely have to order it from them to.
-- The mark of a good carpenter is not how few mistakes he makes, but rather how well he fixes them.
View CharlesNeil's profile
CharlesNeil
855 posts in 2038 days
#9 posted 359 days ago
Thanks for the upshot guys here is a blog I wrote that may help understand prestains a little more
http://intheworkshop.wordpress.com/2012/04/17/applying-dyes-stains-over-my-blotch-control-prestain/
you can also email me if needed Charles@charlesneilwoodworking.com
View SteveTaylor's profile
SteveTaylor
18 posts in 372 days
#10 posted 359 days ago
I working on a desk clock using cherry, and playing around with coloring (not meaning to offend the purists who prefer au natural, but I’m still learning and you can’t learn without risking failure…lol). I mixed a 1b cut clear shellac with a few drops of medium maple transtint dye. Sanded most off to even out the blotching that did happen, but left the color in the grain. The 2 coats of BLO. The results were pretty good, I think. A little more oak than cherry, but nice just the same.
-- "I learn more from my mistakes than my successes....so I learn quite often."
87068 posts in 1745 days
#11 posted 359 days ago
I don’t think you will get any better information than what Charles link states ,I agree with Russ and Ned that Charles blotch control is the best solution for blotching woods.
TCCcabinetmaker
#12 posted 359 days ago
True Jim.
But if you have to buy blotch control from the box stores, use the cabbot, NOT the minwax, that stuff is just ineffective.
#13 posted 358 days ago
TCC
If your talking about Charles Neil’s Blotch control , you buy it from Charles not at a box store and it is not a Minwax product.
View davidroberts's profile
davidroberts
952 posts in 1654 days
#14 posted 358 days ago
Not plugging Rocklers, but their General Finishes Pre-Stain Wood Conditioner works well. I believe most of these conditioners are diluted varnish. Like jmos, I use a washcoat of shellac more often than a store-bought conditioner. You could probably dilute varnish 3:1 with mineral spirits and get the same effect as store-bought. Actually I like some blotching in cherry, not overly blotched, but some is attractive. I like freckles and wine stains too. It’s an acquired taste…
-- david roberts, spinning Tales from Topographic Oceans, no, really.
View OpaTom's profile
OpaTom
3 posts in 533 days
#15 posted 358 days ago
Stick it out in the Sun for a few days!!!!!
