| Forum topic by balidoug | posted 358 days ago | 1026 views | 0 times favorited | 29 replies | ![]() |
358 days ago |
I’m looking for a particular piece of hardware, preferably brass. The search is made difficult because I have no idea what it’s called. Its purpose is to attach/screw the legs of a table or cabinet to the table or cabinet in such a way that they can be removed and stored/transported when desired. I’ve spent days clicking through pages of brass fixtures, fittings, and other hardware, but the closest I’ve found is a means of attaching two halves of a cane (from Rockwell). The photo below, from Elegance Under Canvass by Nicholas Brawer is a fair demonstration of what I’m looking for.
Any idea what it’s called? This brings to mind something else I need. A woodworking reverse-dictionary. I often find myself knowing what I want, but not knowing what to call it. I mean, really, who the heck uses the word “Escutcheon”? I don’t even know how to pronounce it. -- From such crooked wood as that which man is made of, nothing straight can be fashioned. Immanuel Kant |
29 replies so far
#1 posted 358 days ago |
Try this. http://www.leevalley.com/US/hardware/page.aspx?p=40988&cat=3,43576,61994,40988 Steve PS “eskooshun” Lee Valley has them too. -- Steve in KY. 44 years so far with my lovely bride. Think I'll keep her. |
#2 posted 358 days ago |
Steve, thanks. But it looks like a fairly permanent attachment. What I hope to find will have a female with a flange to attach to one part, and a matching flanged male. The idea is to be able to easily pop off the legs when you want to, and just as easily screw them back on. -- From such crooked wood as that which man is made of, nothing straight can be fashioned. Immanuel Kant |
#3 posted 358 days ago |
BTW, thanks for the pronunciation guide. I kept coming out with “eski – mo – tion” which is either an Inuit mobile home or a bad disco tune. -- From such crooked wood as that which man is made of, nothing straight can be fashioned. Immanuel Kant |
#4 posted 358 days ago |
#5 posted 358 days ago |
This may be what you’re looking for: http://www.rockler.com/product.cfm?page=1677&site=ROCKLER. The male & female parts can be glued into the wood and then screwed into each other for a secure and tight fit and then unscrewed to disassemble. Unfortunately you have to purchase the third piece (metal ferrel) but maybe you can use it for another project or even as a tip for the legs if the diameter of the leg is small enough. Another option is a set of “cane couplers” http://www.amazon.com/Cane-Couplers/dp/B000GG5JVI/ref=pd_cp_hi_1 sold in a set and each are a different diameter, presuming you need one for the bottom and top of a cane to disassemble, so if you need 4 couplers of the same diameter, you’ll need to purchase 4 “sets” (8 pairs). -- "They who dream by day are cognizant of many things which escape those who dream only by night." ~ Edgar Allan Poe |
#6 posted 358 days ago |
Jim, Closer. I looked at these (that’s how i stumbled on the cane attachment), but was hoping for a more “elegant” solution. Does this sketch help or just cloud the issue?
#7 posted 358 days ago |
MMH, that’s what I found, and ordered 4. They will serve for the immediate project (I hope) But do not appear to be robust enough for a larger piece. Maybe I have to write to Londonderry brasses. -- From such crooked wood as that which man is made of, nothing straight can be fashioned. Immanuel Kant |
#8 posted 358 days ago |
Worm bolt/nut? I like tee nuts for this type of thing, cheap and as strong as what is between them and the bolt. -- Hear today, gone tomorrow |
#9 posted 358 days ago |
If you don’t stick with the brass idea … The problem with the hanger bolt Another problem is that when you unscew it you are never sure which end of the bolt will unscrew and that is a major annoyance if it is meant to be done frequently. (and if you don’t have a plier at hand) -- Sylvain, Brussels, Belgium, Europe - The more I learn, the more there is to learn |
#10 posted 358 days ago |
ferule – definition of ferule by the Free Online Dictionary, Thesaurus … I do have two children, but I find that duct tape works fine. What exactly do you mean by “ferule”? I think you may be on to something, and a quick look at some hardware sites suggests that ferule may be the word I was looking for (in spite of the above – real! – definition). Thanks! But still open to other eyedeas LJs. -- From such crooked wood as that which man is made of, nothing straight can be fashioned. Immanuel Kant |
#11 posted 358 days ago |
Looking around, I’m not there yet. But getting closer. Thanks everybody. -- From such crooked wood as that which man is made of, nothing straight can be fashioned. Immanuel Kant |
#12 posted 358 days ago |
The threaded inserts are the part that go in the body and wider, they are nut plates They can usually be found with deck hardware (dunno why) and with the screw on pre-made leg spindles. That said… Once you get to table length legs, you have a lot of leverage against stuff. They tend to be pretty wimpy. I would personally get some threaded rod of larger diameter and some rod coupling nuts and set them in epoxy and pin them in. -- Woodworking shouldn't cost a fortune: http://lowbudgetwoodworker.blogspot.com/ |
#13 posted 358 days ago |
First thing is spelling..Ferrule :fer·rule (frl) click for a larger image -- When did quiet and quite become the same word ? I'm guessing about the same time as your and you're did. |
#14 posted 358 days ago |
Dusty, your spelling is more helpful. Mine was more fun. -- From such crooked wood as that which man is made of, nothing straight can be fashioned. Immanuel Kant |
#15 posted 358 days ago |
I use something called a hanger bolt to attach metal standoffs and such to woodwork. It seems these would be suited for your purpose as well. A hanger bolt has lag-bolt threads on one end and machine threads on the other end.
-- "Hard work is not defined by the difficulty of the task as much as a person's desire to perform it.", DS251 |
| Forum | Topics |
Woodworking Skill Share
8781 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1521 |
3542 |
15752 |
Hand Tools
2029 |
Jigs & Fixtures
494 |
Wood & Lumber
2832 |
808 |
Focus on the Workspace
899 |
766 |
Woodworking Trade & Swap
2736 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6148 |
