| Forum topic by revanson11 | posted 358 days ago | 697 views | 0 times favorited | 6 replies | ![]() |
358 days ago |
I need a little advice from my fellow LJ’rs. I’m building a bed and have all the parts cut, sanded and milled. In total I have 28 loose tenons that until two days ago dry fit perfectly in the mortises. Since then we have had over 3 inches of rain and today when I tried dry fitting the tenons none would fit. They have all expanded to the point that they will no longer fit in the mortice. My question is, what’s the best way to reduce the moisture in the tenons to get back to their original size. I thought about placing them in a warm over for a couple of hours to see if that would do the trick but first off I wanted to see what recommendations you all might have for me. Thanks in advance. -- Randy |
