| Forum topic by georgethegoat | posted 365 days ago | 1180 views | 0 times favorited | 23 replies | ![]() |
365 days ago |
Topic tags/keywords: question Fellow wood chippers, I recently found what I’m hoping will be my next table saw. It’s an older jet cabinet saw. Apparently it’s the model before they switched to the white paint. I don’t know much else about it. It seemed to be in decent shape. The biesmeyer fence looked like it needed a little tightening. The belts were in good shape and the motor ran very smoothly The newer jets seem to be running well over $2000 for similar saws. Is this a good price? Are there things I should definitely check for when buying an older saw? Thanks all :-) -- george |
23 replies so far
#1 posted 365 days ago |
First rule of thumb for me, used equipment starts at half the cost of new. So $1000 to me, is like getting a 1 year old tool. Just my opinion. -jeremy -- Easy to use end grain cutting board designer: http://www.1024studios.com/cuttingboard.html |
#2 posted 365 days ago |
$600-$700 would be good for used IMO….maybe a bit more if in really nice shape. I might spend a grand on a used Unisaw or PM66. A new Jet saw includes dealer support and warranty, which don’t apply for a used saw so you shouldn’t reimburse the original owner for those perks. You can buy a pretty comparable saw with a shorter warranty and no dealer support in a Grizzly G1023RL for $1294 shipped, or a G0690 for $1445 shipped. You just have to be your own middle man. -- Happiness is like wetting your pants...everyone can see it, but only you can feel the warmth.... |
#3 posted 365 days ago |
Others might disagree but all of the Jet TS’s Ive used just seem second rate. I think I’d rather have a new Ridgid contractor saw for half the price,Or another brand used cabinet saw like a Powermatic. -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#4 posted 365 days ago |
Jim, I have the Ridgid 4512. I’m trying to get rid of it because it has a slight high spot in the cast iron and i cannot get the blade to stay in line with the miter slots IMO because of a bad alignment design. If you have any secrets to improve this saw I’m all ears. I’d love to hang on to it for financial reasons more than anything but I just can’t seem to get the results I’m looking for. -- george |
#5 posted 365 days ago |
It would have to be in like new condition for me to spend a grand on it , no matter what the brand was. -- When did quiet and quite become the same word ? I'm guessing about the same time as your and you're did. |
#6 posted 365 days ago |
In Los Angeles, no deal. If the saw includes higher-end accessories like a nice miter I expect there were a lot of plant closures in your region which |
#7 posted 365 days ago |
George I owned a 3 HP blue Jet cabinet saw for almost 10 years, I sold it about 3 years ago not because I didn’t like it, I just wanted to own a Unisaw. I always thought the Jet was a quality saw and it served me well. I think I sold it for around $800.00. I did find the blade guard to be labor intensive to install and remove and so it spent most of the time sitting on the shelf.I never thought much about it untill I started using the Unisaw and found the blade guard, riving knife assembly so quick and easy to remove and install (no tools required).The miter gage on the Jet did not fit the slot as tight as I would have wanted so I upgraded to a Incra. Based on my experience if I were looking for another saw a top priority would be a user friendly blade guard/riving knife. -- Ken |
#8 posted 365 days ago |
George -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#9 posted 365 days ago |
George – IIRC the Ridgid R4512 comes with a 3 year warranty(?). If yours has the dreaded alignment issue, it should be covered. Not that a 3hp cabinet saw wouldn’t be a nice upgrade, but Jim’s suggestion could work to your advantage if they’ve given you any hassles with fixing your R4512. -- Happiness is like wetting your pants...everyone can see it, but only you can feel the warmth.... |
#10 posted 365 days ago |
Seems a little steep for an older jet. If you shop around on Craigs list and used equipment resellers you can find newer Unisaws and Powermatics for around the same price. -- If the old masters had power tools, they would have used them. So get off your damn High Horse. |
#11 posted 365 days ago |
George -- Bill R |
#12 posted 365 days ago |
George, I had one of the blue Jet cabinet saws for about 15 to 18 years and just sold it for $1000.00 about a year ago. It had the 52’’ fence and a shop made out feed table. A guy from a local cabinet shop bought for their shop. It was a very good saw. The only reason I sold it was I wanted a new Unisaw. If you do purchase it I have a Wood Dynamics TS Throat Plate and 12 Inserts that I would sell for a great price for that saw if you are interested in zero clearance at the blade. Richard |
#13 posted 365 days ago |
I bought and fixed up a 1980s PM66, putting approximately $900 into the final product (but no motor cover). It works fantastic! But, your need and timing might make your evaluation of this Jet look like a better deal for you. Arch_E |
#14 posted 365 days ago |
Arch_E brings up a good point about “need and timing”. Even though many of us feel that $1000 is a bit steep, most also seem to think it’s a good saw. $600 Unisaws are great when you stumble into them, sometimes at any given time, a $1000 Jet is still the best saw you can buy for $1000. -- Happiness is like wetting your pants...everyone can see it, but only you can feel the warmth.... |
#15 posted 365 days ago |
if the price is too high and it’s not a good deal…. it won’t sell and they will lower the price. from what I’m seeing in the northern New England area…. that saw would not sell at that price. -- Matt, Pine is fine, but Oak's no joke! |
| Forum | Topics |
Woodworking Skill Share
8797 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1535 |
3553 |
15803 |
Hand Tools
2038 |
Jigs & Fixtures
496 |
Wood & Lumber
2844 |
810 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6163 |
