Finish over painted surface in bathroom
Forum topic by jwreels posted 05-23-2012 02:05 PM 1090 views 0 times favorited 6 replies Add to Favorites Watch
View jwreels's profile
4 posts in 3812 days
05-23-2012 02:05 PM
I built a medicine cabinet for a bathroom. It will be painted white. What finish should I go over the painted surface with ? This will be high humidity environment since its in the bathroom.
View Wdwerker's profile
333 posts in 2165 days
#1 posted 05-23-2012 02:30 PM
I have used clear satin water based finishes over paint on a medicine cabinet. The advantage of the water base is no amber tint which would affect the color of your paint.
The bathroom is tiny and has no vent fan, over 2 years of steaming hot showers and the finish is still good as new.
I use ML Campbell’s Aguelente, a pre-catalysed acrylic professional product, but I bet any water base clear should work.
-- Fine Custom Woodwork since 1978
View AJLastra's profile
87 posts in 2161 days
#2 posted 05-23-2012 02:50 PM
Agualente is a terrifc finish…..............if you’re spraying. Never heard that it can be brushed. Are you brushing or spraying your finish?
View Bill White's profile
Bill White
4877 posts in 3892 days
#3 posted 05-23-2012 02:54 PM
Just wonderin’ why you need a finish over a finish?
#4 posted 05-23-2012 03:27 PM
Ah the finish would have to be brushed, I currently don’t have any way to spray.
#5 posted 05-23-2012 03:42 PM
I would check out Endurovar made by General Finishes. It can be sprayed but its made for brushing. This topcoat comes in waterbased and solvent based formulas. The waterbased product is a “go to” finish for noted finishing expert Jeff Jewitt. check out his web page at homesteadfinishing. Hope this helps.
View Doss's profile
779 posts in 2196 days
#6 posted 05-23-2012 03:48 PM
I have, in the past, used automotive clearcoat on painted finishes before (enamel). I like gloss finishes for everything in the bathroom b/c it is less likely to allow water to thin out and saturate a surface (think about misting water onto glass vs sandpaper) which reduces the chance of mold. That’s my theory on that.
-- "Well, at least we can still use it as firewood... maybe." - Doss
