Table Saw Fence Out Of Square!
Forum topic by MichaelAgate posted 05-23-2012 02:12 AM 4250 views 0 times favorited 31 replies Add to Favorites Watch
View MichaelAgate's profile
MichaelAgate
398 posts in 2316 days
05-23-2012 02:12 AM
Topic tags/keywords: craftex busy bee tools una-gauge ct146
Ok, out of square may be a stretch, but it’s the truth. The CT146 by Craftex (busy bee tools) is 3 thousands of an inch out of square. lol, I know, I have it bad. But my question to you is, do you like to have your fence tilt a few thou away from the blade on the back end, or do you like it DEAD ON. We were using the Beterley UNA-GUAGE, with digital readout what do you use?
-- Michael and Matthew
31 replies so far
View jumbojack's profile
jumbojack
1676 posts in 2617 days
#1 posted 05-23-2012 02:20 AM
I get it as close as I can. 3 thou probably not.
View cabmaker's profile
cabmaker
1730 posts in 2802 days
#2 posted 05-23-2012 02:21 AM
Common practice in the real world is to open up the fence about the thickness of a business card. Ive done it for years and many, many others as well. Setting the fence dead on parallel with the blade brings on another set of issues that just dont suit my needs. This setting can vary from saw to saw depending on table depth, etc., etc. Just about anything three thousenths relative to wood is not even a converstion unless were talking about setting planer feed rollers and spindle runouts,etc.
MichaelAgate
#3 posted 05-23-2012 02:30 AM
Thanks cabmaker, I come from a Machinist background and the gauge we are using reads digital, it’s actually made for woodworking tools, run out etc. just happened to use it on the fence this evening. A business card would be about 15 thousandths, so I need to open it up a little. Thanks for your reply!
MichaelAgate
#4 posted 05-23-2012 02:30 AM
Thanks Jumbojack
MichaelAgate
#5 posted 05-23-2012 02:32 AM
Jonathan, that’s why I posted the question, to get everyone’s opinion. tks for your comment.
View Nate Meadows's profile
Nate Meadows
1132 posts in 2200 days
#6 posted 05-23-2012 03:35 AM
Matthew,
I have found there are two types of woodworkers. Those that are “dead ons” and those that are “close enoughs”. There are good arguments for both.
I lean much more to the “dead on” side. It is true that since wood is not a static material it will move over time and so extreme accuracy could be ignored. However, I believe that the closer the tolerances you make it when preparing your work the better your outcome will be. It all stems from a strong foundation.
That being said I think a variance of a credit card is too thick for me. One maybe two thousandths is were I sit.
But again that is just me. You need to find what works best for you:).
Very Respectfully and Gratefully,
Nate
-- "With a little bit of faith, and some imagination, you can build anything!" Nate
View Scot's profile
Scot
344 posts in 3389 days
#7 posted 05-23-2012 04:32 AM
You don’t really want it “dead on”. As you rip a board tension is released which can cause binding on the back side of the blade, which can lead to a kick back. The bussiness card gauge is a good trick to set your fence correctly.
-- If the old masters had power tools, they would have used them. So get off your damn High Horse.
View eddie's profile
eddie
8565 posts in 2607 days
#8 posted 05-23-2012 05:23 AM
MichaelAgate i am a newbee and got my saw from a pawn shop and am just glad it turns on. and i come out with the same amount of fingers when i get thur using it. i just get it as square as i can :)
-- Jesus Is Alright with me
View Fuzzy's profile
Fuzzy
298 posts in 3981 days
#9 posted 05-23-2012 05:28 AM
I set mine dead-on … THEN … I make a few test cuts, and move the rear of the fence away as needed to prevent scoring from the teeth rising from under the table. Once I get the results I want, I lock it down. Don’t be too concerned with a specific number … evaluate the results and let that be your deciding factor.
-- - dabbling in sarcasm is foolish … if you’re not proficient at it, you end up looking stupid … ... ...
View FlairWoodworks's profile
FlairWoodworks
71 posts in 2532 days
#10 posted 05-23-2012 07:57 AM
I toe my fence out a little. Just a little – more than none, less than some.
-- Chris Wong -- http://flairwoodworks.wordpress.com --
View ShipWreck's profile
ShipWreck
557 posts in 3746 days
#11 posted 05-23-2012 08:39 AM
I prefer dead on, but I dont loose any sleep if its off a couple thousands.
View knotscott's profile
knotscott
8005 posts in 3368 days
#12 posted 05-23-2012 09:03 AM
Sometimes these fences aren’t truly straight, meaning “Dead on” or “perfect” don’t exist for them. If you adjust the fence dead on, and your fence bows a smidge in the wrong direction, the result can be binding and kickback. For that reason, I prefer to toe my fence out very slightly….like the thickness of a folded dollar bill….that works great for folks who never move the fence to the other side of the blade to cut bevels, but can cause a “toe in” if the fence gets moved to the opposite side. If you’ve got a left tilt saw and never move the fence to the left of the blade, a slight toe out is safer.
View NiteWalker's profile
NiteWalker
2737 posts in 2570 days
#13 posted 05-23-2012 09:39 AM
I prefer mine out a bit as well.
View americancanuck's profile
americancanuck
414 posts in 2603 days
#14 posted 05-23-2012 10:07 AM
It might work to move the fence by the thickness of a folded dollar bill but here in Canada we don’t have dollar bills and the thickness of a loonie would be way too much.
-- Retired and lovin it
MichaelAgate
#15 posted 05-23-2012 11:58 AM
AmericanCanuck – I died at your comment. LOL yes a loonie may be a bit oversized for this. LOL still LOLing.
showing 1 through 15 of 31 replies
