Easy hold-down while sanding with power.
Forum topic by RussellAP posted 362 days ago 949 views 0 times favorited 15 replies Add to Favorites Watch
View RussellAP's profile
RussellAP
2394 posts in 453 days
362 days ago
Whether you use a vibrating sander or an orbital here is an easy way to hold the work.
Simply put a piece of short nap carpet on your bench large enough to put the work on.
It keeps the work from moving with only the slightest touch on your part.
An added benefit is that it also catches most of the fine dust. You simply take it outside when finished and smack it against a tree to clean it up.
Try it out. Some places sell small squares of this kind of carpet for a $1 or even less.
-- Failure does not stop me, it makes me try harder..... because I'm crazy.
15 replies so far
View Spofeo's profile
Spofeo
105 posts in 364 days
#1 posted 362 days ago
cool idea :)
-- Spofeo/Kristian
View stefang's profile
stefang
9442 posts in 1500 days
#2 posted 362 days ago
Sounds great. Another good idea is to use the rubberized matts that are put under area carpets to keep them from sliding around. Carpet stores usually sell it pretty cheap by the yard from a big roll.
-- Mike, American in Norway
stefang
#3 posted 362 days ago
S
View Ben's profile
Ben
248 posts in 496 days
#4 posted 362 days ago
I use the non slip rug mats like stefang. They work great. I have heard the carpet idea before, but never tried it. I use the non slip mats for sanding and routing.
-- Welcome to downtown Coolsville, Population: US! --Hogarth Hughes
View BinghamtonEd's profile
BinghamtonEd
652 posts in 536 days
#5 posted 362 days ago
I use rubber drawer liner from the dollar store. My wife got over-zealous when we bought the house, and we have about a dozen extra rolls of it. Works real nice and I don’t feel bad about throwing it out when it’s ratty.
RussellAP
#6 posted 362 days ago
Ben, I like the carpet because it catches the fine dust instead of letting it blow around the shop.
86966 posts in 1743 days
#7 posted 362 days ago
Thanks for the tip Russ.
View eddie's profile (online now)
eddie
4572 posts in 780 days
#8 posted 362 days ago
great tip Russell
-- Jesus Is Alright with me
View Bertha's profile
Bertha
13111 posts in 859 days
#9 posted 362 days ago
Stefang, I was in a store once and they were selling “router mats” for $10/sq ft. On the next aisle, they had “carpet pads” for $0.50/sq ft. Go figure!
View 69BBNova's profile
69BBNova
87 posts in 382 days
#10 posted 362 days ago
Thats a pretty good idea…
I spend an inordinate amout of time thinking about how to do things, even as simple as your idea…
A several weeks ago I actually thought that if I had resaw capibilities for cutting veneers I wondered how I could get it thin enough to actually use…
The problem is I dont have a planer and may never have one (just really dont need one)...
I realized that for my purposes I could use double sided wide scotch tape to adhere it to a flat surface when running over it with a hand plane or a sanding block…
I thought about that for years when I do nothing.
Now I need a piece of carpet also.
View Tennessee's profile
Tennessee
1089 posts in 680 days
#11 posted 361 days ago
I use the drawer rubber liner, but there seem to be too types, large hole pattern and small hole pattern. The small one is less grippy, but the large hole seems to catch on sanders and routers easier. For assembly of my guitars, it’s a big terrycloth towel.
-- Paul, Tennessee, http://www.tsunamiguitars.com
View Martyroc's profile
Martyroc
2708 posts in 472 days
#12 posted 361 days ago
Good tip Russ, I have been using a routher matt that I got about 230 years ago and I camn tell you its very well worn by now.
-- Martin ....always count the number of fingers you have before, and after using the saw.
RussellAP
#13 posted 361 days ago
Marty, after I finished my basement rooms I had the carpet remnants rolled up in the garage. I decided one day to use it for sanding when I got tired of all my tools vibrating off the bench and falling to the floor. Now the wood stays put and the dust is caught in the nap of the carpet. Worked out pretty well.
View gfadvm's profile
gfadvm
6611 posts in 856 days
#14 posted 361 days ago
I’ve been using the rubber drawer liners but they get less grippy after some use so I’m anxious to try your carpet tip. Thanks for posting this.
View Lee Barker's profile
Lee Barker
1884 posts in 1016 days
#15 posted 361 days ago
The risk with the carpet is that something harder than what you’re sanding gets threaded in there and you flip over the door or whatever to sand the other side and ugliness happens underneath. I much prefer the sanding mats which you can insure are free of bad stuff. Most of my sanding is done over a sanding table, so the dust collection feature of the carpet is moot.
Kindly,
