Shelf Pin Holes
Forum topic by chip73 posted 367 days ago 642 views 0 times favorited 7 replies Add to Favorites Watch
View chip73's profile
chip73
51 posts in 384 days
367 days ago
Topic tags/keywords: question finishing
Painting a bookcase and what is best practice so I don’t fill the holes with paint. Seems like dowel would work, not sure if paint would run. Looking for ideas before I try something that won’t work.
-- Facts are stubborn things; and whatever may be our wishes, our inclinations, or the dictates of our passions, they cannot alter the state of facts and evidence.
7 replies so far
View cabmaker's profile
cabmaker
1030 posts in 980 days
#1 posted 367 days ago
I dont fill em and have never had a problem.
View Sawkerf's profile
Sawkerf
1776 posts in 1240 days
#2 posted 367 days ago
If I’m painting, I’m probably using a roller so it isn’t much of an issue. If necessary a Q-tip will dab out any extra paint.
A neighbor once painted one of his bookcases with a brush and couldn’t get the piins in the holes. I gave him an old 1/4” drill bit and showed him how to hand twist them clean.
View Clint Searl's profile
Clint Searl
850 posts in 533 days
#3 posted 367 days ago
Don’t drill the holes until after you paint. Nyuk Nyuk
-- Clint Searl.............We deserve what we tolerate
831 posts in 665 days
#4 posted 367 days ago
The last time I did some, I cut a 1/4” dowel into a million pieces and stuffed one in each hole…worked very well. I should point out I was spraying the finish. I saved those dowel pieces for re use if I ever need them again.
-- I long for the days when Coke was a cola, and a joint was a bad place to be (Merle Haggard)
View Charlie's profile
Charlie
686 posts in 457 days
#5 posted 367 days ago
takes far less time to be careful and not fill them with paint than it does to cut a bazillion dowels, paints around them, and then get them out before the paint glues them in place. :)
I usually just do the hand-twist-a-drill-bit when I’m done. Only takes a couple minutes on a big bookcase. It’s GOTTA be faster than cutting dowels, placing dowels, removing dowels.
View DS's profile
DS
1819 posts in 592 days
#6 posted 367 days ago
Wow… I’ve been doing this for 33+ years and this has never been an issue for me.
I usually spray finish.
chip73
#7 posted 366 days ago
Thanks for all the different suggestions. I too am spraying and this will be my first project spraying paint. I could just visualize paint filling in my holes. Just being a little proactive taking advantage of all the experience on LJ.
