| Forum topic by RussellAP | posted 364 days ago | 814 views | 0 times favorited | 7 replies | ![]() |
364 days ago |
This beautiful chair is going on display at Curvy Diva’s in Independence Mo tomorrow. It’s made completely out of cedar (wrc). I only used a couple coats of Spar on it, no stain. As most of you know, WRC comes finished on one side and rough on the other. I prefer to work the rough side because it looks better after sanding. It seems to have a more rich color and the grain is nicer. I reinforced the back leg supports with a single 2×4 and it’s solid as a rock. Anyway here it is.
-- Failure does not stop me, it makes me try harder..... because I'm crazy. |
7 replies so far
#1 posted 363 days ago |
Beautiful job and a beautiful chair. And you right the Western Red Cedar really makes it POP -- DeputyDawg |
#2 posted 363 days ago |
May I ask what you are pricing it at? |
#3 posted 363 days ago |
Nice lawn, Russell! And a really nice chair. -- My dad and I built a 65 chev pick up.I killed trannys in that thing for some reason-Hog |
#4 posted 363 days ago |
JCantin. They are normally $189, but this place I’m demonstrating at charges 20% commission so sales from there will be $199. -- Failure does not stop me, it makes me try harder..... because I'm crazy. |
#5 posted 363 days ago |
I agree with the compliments. I’d just add that rounding those two outside corners on the back brace would make the chair more attractive on a subliminal level. The annoying feature of most Adirondacks is the center splat, which presents a hard surface against which your spine rests. Your four-splat idea counters that nicely. Very good work, Russell. Kindly, Lee -- "...in his brain, which is as dry as the remainder biscuit after a voyage, he hath strange places cramm'd with observation, the which he vents in mangled forms." --Shakespeare, "As You Like It" |
#6 posted 363 days ago |
I just took it apart so I can transport it to Curvy’s. I thought just removing the back would make it so I could get it in my trunk, but the trunk is deeper than tall. I hope I don’t have to deliver many of these. -- Failure does not stop me, it makes me try harder..... because I'm crazy. |
#7 posted 363 days ago |
Lee, the entire back brace will be revamped on the next design. It has to be thick enough to get some screws to bite without poking through anywhere so I’m thinking a 2×6 shaped to fit. I must admit, I did forget to round the corners off, but this way it retains that classic look. I’m a little leary about leaving the back unsupported from the top brace to the top of the slat. This design makes the arms level with the ground whereas other designs brace the back slats higher because they don’t tie into the arms. I thought at one point that if I doweled the back slats about 4 inches from the top, that would do the trick without using more screws, but I absolutely hate dowels. -- Failure does not stop me, it makes me try harder..... because I'm crazy. |
| Forum | Topics |
Woodworking Skill Share
8788 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
78 |
Finishing
1528 |
3547 |
15760 |
Hand Tools
2033 |
Jigs & Fixtures
494 |
Wood & Lumber
2837 |
808 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2738 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6154 |
