Working with spalted wood
Forum topic by mbs posted 05-21-2012 12:53 PM 1977 views 0 times favorited 11 replies Add to Favorites Watch
View mbs's profile
mbs
1657 posts in 3179 days
05-21-2012 12:53 PM
I have a 2” thick spalted walnut that i want to use for a chair seat. The spalted area is in the center and is a half inch thick be two inches wide. Is there something like krazy glue that I can use to harden the soft wood? If so, how does it look when finished and how deep does the glue penetrate? The white part is very soft.
-- Sorry the reply is so long. I didn't have time to write a short reply.
11 replies so far
View tyskkvinna's profile
tyskkvinna
1310 posts in 3225 days
#1 posted 05-21-2012 01:19 PM
How spalted is it? Just enough to change colours, or enough to make the wood noticeably soft/delicate compared to the rest? Or perhaps enough that it looks like it may fall out if you push it too hard.
You can soak it with CA glue. You can also soak it with wood stabiliser. I like the kind from Minwax. For a chair seat, I would consider using epoxy or BarTop type finish on it. That will completely encase it AND provide a durable finish for the chair.
If you get the thin CA (krazy/super) glue, it will soak down pretty hard—and you’re going to go through a lot of it! If you use the thicker glue, it will just settle towards the surface.
-- Lis - Michigan - http://www.missmooseart.com - https://www.etsy.com/people/lisbokt
View bigkev's profile
bigkev
198 posts in 2867 days
#2 posted 05-21-2012 11:27 PM
Google Minwax wood hardener.
I see the back braces in the background. Looks like you’re off to a good start. That’s going to be an awesome seat once you get it finished. The grain matches beautifully.
-- Kevin, South Carolina
View mbs's profile
mbs
#3 posted 05-22-2012 12:04 AM
I have the rockers glued up too. the second chair goes much faster than the first.
I’ll try the minwax.
thanks, guys.
View Tom148's profile
Tom148
39 posts in 2503 days
#4 posted 05-22-2012 12:50 AM
I like that piece of wood. Looking at the end grain it almost looks like you should flip it over and let the grain flair work for you. That’s what I like about figured wood. You almost can’t do it wrong. It is correct if you like it.
God luck with your project.
-- Tom
View mbs's profile
mbs
#5 posted 05-22-2012 08:34 PM
I’ve wondered which way I should orient the wood. I can’t decide which way it would look best.
View Dusty56's profile
Dusty56
11830 posts in 3927 days
#6 posted 06-02-2012 06:37 PM
You might want to flip it over and go with the natural “scallop” of the grain pattern . The picture appears to be “white rot” which is usually pretty punky compared to actual spalting.
View mbs's profile
mbs
#7 posted 06-02-2012 06:45 PM
It is punky. I put minwax wood hardener on it and it’s better but I think I’ll take your advice and turn it over
Thanks.
Dusty56
#8 posted 06-02-2012 11:57 PM
Looking forward to seeing the finished product : )
View woodworker59's profile
woodworker59
560 posts in 2440 days
#9 posted 06-06-2012 04:38 AM
I second the flip, you could almost follow the natural flow of the grain to make your hollows in the seat.. you gotta love black walnut it makes a great chair.. Are you by any chance making Sam Maloof type chairs? I did notice you mentioned rockers and he loved to make his rockers out of black walnut.. just wondering..
remember the pics…...
-- Papa...
View Dusty123's profile
Dusty123
29 posts in 2440 days
#10 posted 06-06-2012 04:51 AM
You can use System 3 Epoxy to harden up that area of the wood. There is a fast, med and slow cure. Get the slow cure for the especially in the hot summer months. You want the epoxy to set up very slowly so it can be adsorbed by the wood. This will darken the wood quite a bit, but will make it very strong. If yo are not familiar in using this epoxy, make sure you keep the ratios correct and mix it for several minutes just to make sure.
View mbs's profile
mbs
#11 posted 06-06-2012 11:50 PM
Woodworker59 – I’m using Hal Taylors design which is similar to Sam’s. I have a blog that shows the first rocker I made with Leopard wood and walnut.
I decided to flip the seat. The minwax hardened enough for bottom of the seat. I do have some system 3 epoxy too if i need it.
thanks to all that commented.
