How many people use their table saw as their primary work surface?
Forum topic by Alan S posted 05-20-2012 01:47 AM 2688 views 0 times favorited 31 replies Add to Favorites Watch
View Alan S's profile
Alan S
181 posts in 3516 days
05-20-2012 01:47 AM
I’m curious if I am the only one. I really don’t have the room in my 1 car garage workshop for a bench, so I end up using my table saw for assembly and bench work. Do you put a board down before working with glue? I am constantly cleaning glue spots off my cast iron table saw top.
Alan
31 replies so far
View RussellAP's profile
RussellAP
3104 posts in 2485 days
#1 posted 05-20-2012 01:58 AM
I only use it when I’m sharpening my plane iron. I have a 3×8 bench with a couple shelves on the back which is a catchall for stuff, but my primary bench is a piece of MDF 4×4 on a couple of home made horses I joined with 2×4’s. It’s the center of the workshop now and I do everything on it. I do need to make a frame that fully supports the MDF though because it’s starting to sag on the ends.
View jerrells's profile
jerrells
918 posts in 3083 days
#2 posted 05-20-2012 02:33 AM
Alan – I am with Russell. YES I have a work bench but I use a 2×4 sheet of ply on some saw horses or IF I need bigger I have a old door I will put on them. A lot of times I will have to leave MY car out of the garage for a period of time but it works.
-- Just learning the craft my Lord and Savior Jesus Christ practiced.
View cracknpop's profile
cracknpop
334 posts in 2548 days
#3 posted 05-20-2012 02:35 AM
I admit, I still use mine as a part time assembly bench, though not as much as I did before building a rolling bench, 16” X 60” that expands out to 48X60. I would most always put a sheet of MDF on top my table saw when using as assembly/finishing bench. Also, like Russell, I have several sets of folding saw horses that I top with MDF/plywood to work off of as well.
-- Rick - I know I am not perfect, but I will keep pressing on toward the goal of becoming all I am called to be.
View Dallas's profile
Dallas
3599 posts in 2686 days
#4 posted 05-20-2012 02:40 AM
Alan, I was in the same spot for awhile.
Make sure you keep a good coat of Johnson’s Paste wax on the work surfaces… Glue won’t stick, mitre gauge works better and it’s a lot nicer than a dose of salts!
View richinva's profile
richinva
11 posts in 2698 days
#5 posted 05-20-2012 10:27 AM
Tablesaw? Is that the thing with all those bowl blanks on it?
View canadianchips's profile
canadianchips
2613 posts in 3196 days
#6 posted 05-20-2012 10:39 AM
No, NO ,NEVER !
I work out of a single car shed, I do NOT use the Table Saw for anything other than cutting. It is NOT a storage area, It is NOT a assembly table. At our cabinet school it was drilled into us NEVER use the saw for anything other than cutting, It sticks with me today——35+ years later.
View kizerpea's profile
kizerpea
775 posts in 2566 days
#7 posted 05-20-2012 11:53 AM
Why yes i do…...............even tho i do have a 4 by 8 table…...the table saw is the comand center for the shop…thats where i,m sitn now…posting my 2cents…..sitn on a stool cruzn LJ…drinking coffee…
-- IF YOUR NOT MAKING DUST...YOU ARE COLLECTING IT! SOUTH CAROLINA.
View TrBlu's profile
TrBlu
386 posts in 2824 days
#8 posted 05-20-2012 11:58 AM
For me it is the router table. I have a workbench, but the router table is usually empty, where the bench is almost always cluttered.
-- The more I work with wood the more I recognize only God can make something as beautiful as a tree. I hope my humble attempts at this craft do justice by His masterpiece. -- Tim
6866 posts in 4178 days
#9 posted 05-20-2012 12:01 PM
No, it’s only used as a table saw.
And no drinks on it or the attached table surface either.
View David Craig's profile
David Craig
2137 posts in 3307 days
#10 posted 05-20-2012 12:09 PM
I have a small workshop in the basement. I never used the tablesaw as a work area. One of the concerns I have, asides from damaging the surface area of the saw, is leaving behind any small tools or items that I may have forgotten to pick up before starting up the saw. Forget to pick up one small router bit and you have an opportunity to chip a blade, have it catch and get thrown at you, or find your reflexes kicking in and putting your hand in the blade to try and grab the bit before it is picked up. All bad things.
View 8iowa's profile
8iowa
1587 posts in 3960 days
#11 posted 05-20-2012 12:16 PM
In Gainesville, I work in a one car garage space slightly under 200 sq ft. There I have a Scandinavian type work bench and a 6’ 2” long 24” deep storage cabinet with a 3/4” plywood top which is designed to mount numerous tools.
These are my work spaces. I don’t like to even put my coffee mug on the saw table surface.
View Bill White's profile
Bill White
5123 posts in 4159 days
#12 posted 05-20-2012 02:01 PM
There is a sign (paper and moveable) on my TS top that threatens death and destruction to ANYBODY that puts ANYTHING on it. My workbench and outfeed table are used for assembly (or as-em-bully) as the NORM says.
Bill
-- bill@magraphics.us
View BilltheDiver's profile
BilltheDiver
260 posts in 3084 days
#13 posted 05-20-2012 02:33 PM
My tiny shop is overcrowded with my tools so , Yes I do use my unisaw as a work surface. As a suggestion, buy a roll of butcher’s paper and use that when you are going to do glue work to protect the surface. Cheap and disposable.
-- "Measure twice, cut once, count fingers"
TopamaxSurvivor
18389 posts in 3875 days
#14 posted 05-20-2012 07:16 PM
when its handy, do it! ;-)
View RibsBrisket4me's profile
RibsBrisket4me
1554 posts in 2704 days
#15 posted 05-20-2012 07:59 PM
Get a workmate. Or get two plastic foldable sawhorses and a piece of MDF…I also don’t have a stand alone work bench and do have to use my table saw to work on.
showing 1 through 15 of 31 replies
