Big Sanding Error
Forum topic by chip73 posted 05-19-2012 11:06 PM 1159 views 0 times favorited 5 replies Add to Favorites Watch
View chip73's profile
chip73
55 posts in 2335 days
05-19-2012 11:06 PM
Topic tags/keywords: question sanding filler
Need a little help! My face frame was not flat on the back (joint to joint) on one side so I sanded a little bit of a dip in my frame. Now my shelf has a gap between it and the face frame. I am sure I can fill though its large, not sure which filler would be the best under this issue. I am painting this piece. Is a water based filler or an epoxy the best, looking for suggestions. If not for this small detour I had a wonderful day in my shop.
-- Facts are stubborn things; and whatever may be our wishes, our inclinations, or the dictates of our passions, they cannot alter the state of facts and evidence.
5 replies so far
View NiteWalker's profile
NiteWalker
2737 posts in 2698 days
#1 posted 05-20-2012 01:26 AM
I’ve used regular wood filler for things like that in the past on painted projects with no problems.
Make sure to use a good primer.
View Bernie's profile
Bernie
422 posts in 2959 days
#2 posted 05-21-2012 02:30 AM
Since you’re painting, options are open for you. Fillers are good but depending on the depth of your space, you may have to fill it in steps. One option you have not mentioned is wood. When I make those kinds of mistakes, I like to carefully chose a piece of the same species of wood with a matching grain. I always cut the filler a bit larger (especially thickness) and glue it in place. The next day I trim it flush, stain it, and nobody ever sees it.
-- Bernie: It never gets hot or cold in New Hampshire, just seasonal!
chip73
#3 posted 05-22-2012 12:13 AM
I had not thought of the wood as a filler. That makes sense based on the fact I’m painting.
View fredf's profile
fredf
495 posts in 3832 days
#4 posted 05-22-2012 10:17 PM
Bondo works great too. paint hides a multitude of sins!!
-- Fred, Springfield, Ma
View DKO's profile
DKO
12 posts in 2487 days
#5 posted 05-22-2012 10:37 PM
I am a big fan of bondo for large gaps if you are painting. It doesn’t shrink and is very hard.
