Vintage Delta/Rockwell Band Saw
Forum topic by henrie posted 396 days ago 1485 views 0 times favorited 4 replies Add to Favorites Watch
View henrie's profile
henrie
1 post in 400 days
396 days ago
Topic tags/keywords: question
I am trying to pull the 20” wheels off to change bearings, but am having trouble. There is what looks like a snap ring except it’s not. Been using penetrating oil on it for weeks. The upper wheel is not keyed and also has this ring, but the bottom wheel has a key and this ring. can anyone advise me on how to get these wheels off?
View MedicKen's profile
MedicKen
1561 posts in 1659 days
#1 posted 395 days ago
Henrie…..which model of bandsaw is this? 28-350?
Take a look here and find your model and then download the manual. It should also have a parts diagram.
From what I have read it take some patience, a LOT of GOOD penetrating oil, like Kroil or PBblaster, and a puller. Some pics of the wheel may also help in determining how to remove it.
View 47phord's profile
47phord
137 posts in 434 days
#2 posted 395 days ago
Can you post some pictures?
MedicKen
#3 posted 394 days ago
It sounds like the “ring” you are referring to is probably a hub. If so, there will be some tapped holes at 180 degrees to each other in the ring. Screw a bolt into the holes and tighten them. It should pop the hub loose and then the wheel will come off the shaft.
View AHuxley's profile
AHuxley
208 posts in 1519 days
#4 posted 394 days ago
The Delta 28-350 (rounded) and latter 23-3×0 et al (square) saws don’t have wheel bearings as such, the wheels are mounted on a rotating axle which has two bearings.
If it is a 28-350 (not sure about the later square saws) it will have two set screws at 90* when loose the wheel should slide of the shaft, if not a 3 arm gear puller may be needed but you have to careful the webs are thin, I would back them with something. The top and bottom both use different sized bearings so you actually need 4 different sized bearings an 87502, 87504, 87505 and 87506 if memory serves.
The later saws use the same rotating axle but I am not sure of the orientation of the set screws or if they changed the bearing size but the basic setup is the same.
