| Forum topic by HelenMA | posted 370 days ago | 1134 views | 0 times favorited | 10 replies | ![]() |
370 days ago |
Hi, My last resort is to take up the floor but I don’t want to do that. When we built the shed, we used 2 layers of pressure treated plywood and finished it with a layer of regular plywood for a total of 3 layers. Any ideas or suggestions? The shed also has a lean-to attached. Thank you! |
10 replies so far
#1 posted 370 days ago |
Is the plywood on the ground? -- "some old things are lovely, warm still with life ... of the forgotten men who made them." - D.H. Lawrence Wake Up America!! Please read; http://www.commondreams.org/view/2009/01/26-0 |
#2 posted 370 days ago |
It sounds like you will need to at least cut a hole in the floor, if you do it carefully you can add a couple blocks and put the same pieces back down after you level out the ground underneath when your through. -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#3 posted 370 days ago |
When we built the shed my Uncle used stakes to raise the floor. I just remember three layers for the floor but it was not on the ground. I’ll post some pics, been working on it all morning. The picture showing underneath the shed has a peice of vinyl siding there. I’m trying to take off the wire mesh to try and pull it out. But I’ve tried philips head, square, and star shaped screw heads but none are working. Inside you can see the slant to the left. I’ve been using a black plastic plumbing pipe and hammering it in under the shed then dumping the dirt but its a slow process! Thanks to all for offering suggestions! I REALLY appreciate it! |
#4 posted 370 days ago |
Is there any chance the rest of the shed has sunk and the bump is from one of the stakes in the ground? -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#5 posted 370 days ago |
I guess its possible but I caught 2 woodchucks and 5 skunks living under there this past year. Also a few opossums. I think its from the burrowing but I might be wrong. Also, the door hits the floor more towards the center or when its open about halfway. |
#6 posted 370 days ago |
If it’s not too high and the plywood is thick enough, you might be able to plane the floor with a power planer, then coat it with whatever you’re using to preserve the wood. -- Failure does not stop me, it makes me try harder..... because I'm crazy. |
#7 posted 370 days ago |
Looks like the door is metal Russ? I’m a contractor of 25 years Helen and I’ve never seen wild life raise a floor only cause it to sink, I do lots of work on country property. You might take a level and see if the back of the shed is higher than the front,if you don’t have a long level you can lay a straight 2×4 on the floor and put a level on top of it. If the back is higher than the front then the front has sunk due to being undermined by those critters. -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#8 posted 370 days ago |
I’ll try the level to see if that’s the case which it could very well be. I just did the side of the shed (inside the lean to) and removed the siding I could reach. The soil is right up against the bottom of the floor and packed hard. What I did notice is that the corner where the lean to attaches to the shed is off, a space is there. So that makes me think you are right Jim. How do I jack up the shed? I know I have to get those cement footings to put underneath to support it. Also, do I jack up the outer part of the lean too at the same time? Or is this something I should hire someone for? Russell, I tried sanding the area near the door but it needs alot of sanding. I might try that too again. Thanks again!!! |
#9 posted 370 days ago |
It looks like the floor joists are directly on the dirt. If that is the case, I’d think you would have to jack up the entire shed and install some deck piers under them after the ground is leveled, or have some concrete poured under it for a foundation. There is just no easy fix sometimes. -- Failure does not stop me, it makes me try harder..... because I'm crazy. |
#10 posted 370 days ago |
Hi Helen -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
| Forum | Topics |
Woodworking Skill Share
8798 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1537 |
3554 |
15806 |
Hand Tools
2039 |
Jigs & Fixtures
496 |
Wood & Lumber
2846 |
810 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2741 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6165 |
