Building Entry Doors Out Of Aromatic Cedar?
Forum topic by Koa posted 370 days ago 885 views 0 times favorited 6 replies Add to Favorites Watch
View Koa's profile
Koa
59 posts in 640 days
370 days ago
Topic tags/keywords: resource question cedar bandsaw carving tool lathe planer scroll saw chisel drill press miter saw router spray gun blade clamp jointer plane sander tablesaw milling shaping turning finishing joining sanding arts and crafts rustic greene and greene
Well, I wanted to make my shop entry doors ” http://lumberjocks.com/Koa/blog ” out of Aromatic Cedar, but I have concerns about the long term stability of the timber. Is it tough enough to withstand the abuse entry doors go through on a day to day basic? I think I will be ok with the stability, has anyone had any experience using it to build windows and doors? Any help or input anyone can offer would be appreciated!
-- An aspiring woodworker.
View WDHLT15's profile
WDHLT15
687 posts in 647 days
#1 posted 370 days ago
It is very stable wood, and that is good for doors. It is soft, however, and may get dinged up more than say oak or maple. However, many doors have been made of pine, and it is softer, too. Just design them to be stout, maybe a little thicker, and I bet that they will be beautiful.
-- Wood-Mizer LT15
View PRGDesigns's profile
PRGDesigns
177 posts in 484 days
#2 posted 369 days ago
You might also consider a sandwich type construction of alternating layers to get thickness you need for the doors. Think of a sheet of Plywood on steroids.
-- They call me Mr. Silly
View lwllms's profile
lwllms
466 posts in 1452 days
#3 posted 369 days ago
I made a swing set of aromatic cedar for my daughter when she was little. She’s 26 now and I took it down a couple years ago. It spent years outside and was still solid when I took it down. It had a play house above the swing set and the ladder took a lot of abuse over the years. It was still solid but looked pretty rough.
View Koa's profile
Koa
#4 posted 369 days ago
WOW . . .
Thank you all for you feed back, GREAT INPUT. If anyone else has any experience using aromatic cedar I would love to here from you. I think I will began the planning possess for the doors. HOPE they turn out ok . . . I will post pictures when I get them completed. . . .
Thank You
View bondogaposis's profile
bondogaposis
1254 posts in 522 days
#5 posted 368 days ago
It trends to have a lot of knots that will cause problems w/ the joinery, no doubt. I’m sure it could be done though.
-- Bondo Gaposis
View HalDougherty's profile
HalDougherty
1820 posts in 1408 days
#6 posted 368 days ago
I made my shop door from 1X6” poplar boards. The outside frame is made from two box frames with a center spacer that I glued together after fitting the panels. The joints at each corner alternate so there’s support after they are glued together. I cut a 3/8” rabbet all around the interior, then made 1X6” boards with an alternate rabbit on the top and bottom and a matching 3/8” rabbit on the ends. I made the outside from poplar only and on the inside, I put 1X6 Eastern red cedar boards. Then I glued the two 1” frames together to make a door with floating panels on each side. It was a one day job and all of it was cut out with a skill saw so there’s a few places where the fit isn’t perfect, but it’s a door to an unheated garage. It’s functional and looks better than the rest of the garage.
-- Hal, Tennessee http://www.first285.com
