A comment on the old Craftsman (Belsaw) thickness planers
Forum topic by Planeman40 posted 05-18-2012 03:40 PM 17995 views 0 times favorited 37 replies Add to Favorites Watch
View Planeman40's profile
Planeman40
1179 posts in 2788 days
05-18-2012 03:40 PM
Topic tags/keywords: belsaw planer
Yesterday a friend and I finished up cutting up some hardwood logs (pear wood) and running the boards through my old (early 1970s) Craftsman 12” planer which is simply a Belsaw planer with a Craftsman nameplate. I have had this planer since I bought it new. In those days there were no thickness planers made for home workshop use other than a little 6” one and the 12” Belsaw. Belsaw advertised every month in Popular Mechanics and Popular Science magazines for many years so I was familiar with the brand name. Also, Belsaw planers have the appearance of a crudely made machine, but it was all that was available unless I wanted to pay out big bucks for a huge cast iron industrial monster that I couldn’t afford. Reluctantly, I bought a Belsaw and found to my surprise and delight that it worked beautifully! Now after 40 years of use I thought I should comment that it still works beautifully. I do take care of my machines and clean and lubricate them often.
So I thought I should say to all of you that are looking for a used 12” planer, don’t dismiss the Belsaw because of its looks. Its a good machine that holds up and does a nice job. I would love to hear comments here from other Belsaw owners.
Planeman
37 replies so far
View Loren's profile
10476 posts in 3675 days
#1 posted 05-18-2012 05:36 PM
I have a Belsaw and really like it.
View kansas's profile
kansas
165 posts in 3728 days
#2 posted 07-14-2012 12:57 AM
I just bought a belsaw. Mine is 5hp 12” model. Looks to be in good decent shape and was made by powermatic. It needs planer knives but came with a few molding cutters. Previous owner had a catalog from www.belsaw.com so I went ahead and ordered the knives. I’ve only tinkered with it a short time and would really appreciate any tips on adjustment, operation, etc.
Planeman40
#3 posted 07-14-2012 01:31 PM
Not much to say about adjustment.
Planer and jointer knives should all have the same depth of blade measurement (cutting edge to back of blade) even after they are sharpened. This allows you to easily replace the blades as long as you don’t alter the blade height adjustment. So leave the blade height adjustment alone unless you have an unusual problem. Also, when changing blades be sure to put a few layers of masking tape along the cutting edge to keep from slicing yourself while doing the blade change. Other than that, blade changing is easy.
Be sure the infeed and outfeed extensions are carefully bolted on to make for a smooth transition of the wood through the machine. For what its worth, I haven ever had any problems with “snipe” due to the long extensions on my machine. I do support long boards on infeed and outfeed by hand though.
I can’t think of any other adjustments that are needed. Just keep the machine clean and well lubricated and all should be well.
Planeman
View Don W's profile
Don W
18754 posts in 2594 days
#4 posted 07-15-2012 08:19 PM
I just picked on up yesterday. http://lumberjocks.com/topics/39731
The plate says its a 306-9127
I can not find any information on it. It looks a lot like the 9123. http://vintagemachinery.org/photoindex/detail.aspx?id=8872
I want to make sure i can get parts before I start putting her back together.
Planeman40
#5 posted 07-15-2012 08:40 PM
That’s the same Sears/Belsaw planer I have. Looks to be in good shape except for a little surface rust that will quickly clean up with a wire brush in a drill. Nice haul!!!
Planeman
#6 posted 07-15-2012 08:50 PM
Parts are going to be pretty much the same as the Belsaw
machines. One thing you can say of them is that once
they figured out how to build the machine right they
didn’t hurry to try to improve it. They are simple
mechanically and you can see everything easily.
The machine makes some noise when running due
to the feedworks. Still quieter than a benchtop
planer but has kind of an old-fashioned rattle and
clack vibe about it.
Planeman40
#7 posted 07-15-2012 09:09 PM
Here is what the Belsaw planer has become . . .
http://www.woodmastertools.com/712
I’ll bet a number of parts are still available.
Planeman
Don W
#8 posted 07-15-2012 09:32 PM
Planeman, any chance I can get some close up pictures of the motor mounts. I’ll need to make some new ones as mine are missing.
Planeman40
#9 posted 07-15-2012 10:08 PM
I’ll see if I can find my camera.
The motor mounts couldn’t be any simpler. Just two 1 1/2” x 1 1/2” pieces of angle iron bolted atop the horizontal braces of the legs of the stand. The motor just bolts on to the angle irons.
Planeman
View richardwootton's profile
richardwootton
1699 posts in 1982 days
#10 posted 04-19-2013 08:51 PM
Sorry to revive such an old thread, but there’s a 12” Belsaw on CL right now for $375 and I don’t know if that’s a good deal. Used planers so rarely become available in my area, and very rarely for an affordable price. What do y’all think?
-- Richard, Hot Springs, Ar -- Galoot In Training
Don W
#11 posted 04-19-2013 09:25 PM
it depends on condition. If its in top notch working condition, its probably worth that. I wouldn’t sell mine for $375.
Planeman40
#12 posted 04-19-2013 10:10 PM
I agree with Don W. Just make sure its all there and not damaged. You can probably knock him down to $325 or so, but I would take it at $375 if its all there and in good condition.
Surface rust can easily be removed with a wire brush in a hand power drill. When you get it cleaned up, Spray it all over with WD-40 and let it sit overnight, then wipe it down. WD-40 leaves a coating that seeps into the pores in the metal and displaces any moisture. It then leaves a thin coating that inhibits rust. The coating will not come off on you work once its dry. And be sure to put some light oil in the little oil dimples of the Oilite bearings. You will find these easily.
Planeman
#13 posted 04-19-2013 10:11 PM
With a 5hp motor and the rollers in good condition, it
would be a fair price. I paid $250 for mine and I have
seen them on Craigslist for less, but I’m in Los Angeles
and there’s a big supply of used machines here.
It’s a really good planer.
View Gary Scoville's profile
Gary Scoville
27 posts in 1551 days
#14 posted 07-15-2014 08:49 PM
Hi guys! I just finished repairing and updating my Craftsmen (BelSaw) 12” planer/shaper with nice new knives and in-feed and out-feed rollers and two new Power Twist V-Belts. They are on the 5 hp motor with dual pulley’s. Now all I need to do is get some help setting it up to work! That’s were I hope you guys can help me out. I think I got it for a fair price but I’m new to this trade and may have payed a bit to much. Anyway, if any of you fine folks out there can help me out, that would be awesome! Thanks again in advance….
-- Gary Torrington, CT
View Bill White's profile
Bill White
4949 posts in 3987 days
#15 posted 07-15-2014 10:31 PM
You guys are makin’ me crazy(er). I don’t know why I can’t find treasures such as those here in Mississippi.
Here, we always used an axe for trim/finish work. :)
Bill
-- bill@magraphics.us
showing 1 through 15 of 37 replies
